HOLESAW,VARIABLE PITCH (1")
Bi-Metal Hole Saws
Cat No:
825-1
UPC No:
783310191384
Description
Cut through steel, tin, aluminum, fiberglass, wood and plastic
Deep 1-5/8 IN (41.3 mm) cutting depth allows for cuttingthrough 2 IN x 4 IN wood studs
Extra-tough bi-metal blade- we use the highest grade oftool steel to outlast competitor's blades.
That beats premature saw replacement and savesyou money
Steam oxide finish - no paint to gum up and slow cutting. The saw runs cooler for longer life and
better performance
Extra-thick backplate minimizes vibration for smoother, easier, less tiring cutting
Made in USA
Specifications
Cutting Size : 1-5/8 IN
Hole Diameter : 1.000 IN
Material : Bi-Metal
Pipe Tap Size : 3/4 IN
Type : Variable Pitch
Use With Quick Change Arbor No. : 2800
Use With Standard Arbor No. : 37157, 37155 Or 38522
很抱歉,暂时无法提供与“825-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货 - 国内价格
- 1+ 17.16 1+ 0
- 10+ 15.84 10+ 0
- 50+ 14.52 50+ 0
- 100+ 13.2 100+ 0
- 国内价格
- 1+ 38.30564 1+ 0
- 4+ 28.90291 4+ 0
- 11+ 27.3338 11+ 0
- 国内价格
- 1+ 56.46429 1+ 0
- 3+ 40.28201 3+ 0
- 8+ 38.09004 8+ 0
- 国内价格
- 1+ 58.11726 1+ 0
- 6+ 56.99132 6+ 0
- 12+ 54.79935 12+ 0
- 国内价格
- 1+ 89.06841 1+ 0
- 2+ 86.28951 2+ 0
- 3+ 83.18721 3+ 0
- 4+ 81.58216 4+ 0
- 国内价格
- 1+ 107.05936 1+ 0
- 2+ 102.61553 2+ 0
- 4+ 97.0218 4+ 0
- 国内价格
- 1+ 108.48475 1+ 0
- 2+ 107.67024 2+ 0
- 3+ 104.5919 3+ 0
- 4+ 101.80102 4+ 0
- 国内价格
- 1+ 203.97336 1+ 0
- 2+ 192.86976 2+ 0
- 10+ 190.84547 10+ 0
- 国内价格
- 1+ 232.39716 1+ 0
- 2+ 219.71245 2+ 0
- 国内价格
- 1+ 285.11233 1+ 0
- 2+ 269.58885 2+ 0
- 国内价格
- 1+ 298.49176 1+ 0
- 2+ 282.20168 2+ 0
- 国内价格
- 1+ 1.5444 1+ 0
- 10+ 1.5012 10+ 0
- 30+ 1.4796 30+ 0
- 国内价格
- 1+ 4.8492 1+ 0
- 10+ 4.3632 10+ 0
- 30+ 4.0932 30+ 0
- 100+ 3.8016 100+ 0
- 国内价格
- 1+ 10.584 1+ 0
- 10+ 8.9532 10+ 0
- 30+ 7.938 30+ 0
- 100+ 6.8904 100+ 0
- 500+ 6.426 500+ 0
