KUXRL6-00WCNUV
KUXRL6-00WCNUV
    EATON(伊顿)
    TERMINALBLOCKKUXRLSERIES
KUXRL6-00WCNUV 数据手册
Series KU Base Mount Double Row Terminal Blocks GET CONNECTED WITH US SPECIFICATIONS Rating: 60A, 600V* Center Spacing: .625” (15.88 mm) Number of poles: 2 - 12 Wire Size: AWG #6 CU max. Screw Size: #10-32 brass nickel plated Torque Rating: 20 in/lb max. Distance Between Barriers: .437” (11.09 mm) Mounting: Base mount. For 35mm DIN rail mountable, consult factory. Material: Molded base: Black, UL rated 94V-0 thermoplastic. Terminal plating: Nickel over brass. Screws: Nickel plated brass. Operating Temperature: 105°C max. Approvals: UL E62622; CSA LR15364; CE Pending No. of Poles A KU B KUX only A 2 3 4 5 6 7 8 9 10 11 12 2.50 3.12 3.75 4.37 5.00 5.62 6.25 6.87 7.50 8.12 8.75 1.62 2.25 2.87 3.50 4.12 4.75 5.37 6.00 6.62 7.25 7.87 2.00 2.62 3.25 3.87 4.50 5.12 5.75 6.37 7.00 7.62 8.25 KUSC4 KU12 B .62 (15.88) 1.50 (38.10) 2.00 (50.80) #10 screw clearance 1.25 (31.75) .43 (11.09) Dimensions in inches. To convert to millimeters, multiply by 25.4. .50 (12.70) *60A rating achieved with #6 copper wire crimped to ring terminal A Part Numbering System Series Poles Screw Options Covers Marking Strip K■ U ■■■ ■ ■■ ■■ ■■ ■■■ 00 - screws shipped bulk W - brass washer head, nickel plated P - Steel screw w/pressure plate zinc plated B - brass washer head, no plating WC - Top cover & 2 end plates MT - Matte finish NU - Numbered 1 to 12, horizontal NUV - Numbered 1 to 12, vertical PT - Marker strip for cover KU KUX KUSC - Standard block 2 to 12 - Short block - Standard w/shorting strap & 4 shorting screws KURL - Standard w/removable link KUXSC - Short block w/shorting strap & 4 shorting screws KUXRL - Short block w/removable link Accessories MTMU## Molded Marking Tape Matte Finish NUM## Molded Marking Tape JU12 Jumper 12 Circuits NUE End Piece for NUC NUC## Cover BIF document: 1421 For complete specification data, call Bussmann Information Fax ~ 314.527.1450 14
KUXRL6-00WCNUV
物料型号:KU系列端子台,包括标准块(KU)、短块(KUX)、带短路带和4个短路螺钉的标准块(KUSC)、带可拆卸连接的标准块(KURL)、带短路带和4个短路螺钉的短块(KUXSC)以及带可拆卸连接的短块(KUXRL)。
器件简介:这些端子台适用于基座安装,具有60A、600V的额定值,中心间距为15.88mm,可支持2至12个极点的配置。
引脚分配:表格中列出了不同极点数量的端子台尺寸,单位为英寸,可通过乘以25.4转换为毫米。
参数特性:包括最大操作温度105°C,UL E62622、CSA LR15364认证,CE认证待定。
功能详解:文档提供了端子台的尺寸信息、螺钉规格(#10-32黄铜镀镍)、扭矩等级(最大20 in/lb)和端子之间的距离。
应用信息:适用于需要端子连接的应用,如电气面板、控制系统等。
封装信息:提供了端子台的材质信息,包括黑色UL 94V-0热塑性材料的模制基座、镍上镀黄铜的端子镀层、以及镀镍黄铜螺钉。
KUXRL6-00WCNUV 价格&库存
很抱歉,暂时无法提供与“KUXRL6-00WCNUV”相匹配的价格&库存,您可以联系我们找货
