BK/CB1911-10
BK/CB1911-10
    EATON(伊顿)
    BK/CB1911-10
BK/CB1911-10 数据手册
Consumer Aftermarket Product Catalog Automotive Circuit Breakers Consumer Aftermarket Catalog Automotive Circuit Breakers Cooper Bussmann offers the industry's largest selection of automotive circuit breakers including both OEM-style and fuse-replacement devices. Circuit breakers are designed to offer a variety of performance characteristics including three types of reset. (NOTE: Always follow the OEM's recommendations when replacing circuit breakers. Replace only with the same type breaker in aftermarket applications.) Type I - Automatic Reset Circuit breaker automatically resets after opening. If the fault still exists, the breaker will continue to cycle between ON and OFF positions until the overload is corrected. These devices are sometimes called "cycling breakers." Type I/Automatic Reset circuit breakers do not address, or correct, overcurrent or fault conditions. They only react by cycling OFF and ON. Any overcurrent or fault condition that causes any Type I circuit breaker to operate should be corrected as soon as possible. Continual vehicle operation under an overcurrent or fault condition (causing the Type I circuit breaker to cycle) is NOT recommended. Type II - Modified Reset The circuit breaker will remain tripped (in the OFF position) as long as there's power to the circuit, due to an internal resistor. Type II breakers can be reset by turning off the circuit, or by turning off the ignition switch. These devices are sometimes called "non-cycling breakers." Several Cooper Bussmann Type II breakers feature silver-colored bodies. Type III - Manual Reset The circuit breaker will remain tripped (in the OFF position) until an indicator button or lever is manually reset. Type III breakers are also available with a switchable feature, which allows you to use an external button to disable the circuit. Cooper Bussmann circuit breakers feature our patented fail-safe technology - offering an innovative element design which combines the resetable performance of circuit breakers with the short-circuit protection of a fuse. • Resetable, to work like a normal "cycling" breaker, in low overload conditions. • Under severe overload or short-circuit conditions, the breaker's element will open to prevent damage to the circuit. Blade-Type Breakers Cooper Bussmann blade-type circuit breakers are available in several reset modes that correspond to SAE categories: SAE Type I (automatic reset), SAE Type II (modified reset) and SAE Type III (manual reset). All Cooper Bussmann blade-type circuit breakers utilize carefully designed and manufactured snap-acting thermal elements with precious metal electrical contacts. See page 6 for circuit breaker specifications. 12 ATM Footprint Breakers CB211 and CB212 Cooper Bussmann ATM footprint breakers match the blade footprint of ATM fuses. Ultra-thin, to fit in tight spaces - they're the smallest automotive circuit breakers on the market. Cooper Bussmann ATM footprint breakers comply with SAE standard J553. CB211 Type I ATM Footprint Circuit Breaker Part No. (Amps) Blister Pack CB211-71/2 CB211-10 CB211-15 CB211-20 CB211-25 CB211-30 X X X X X CB212 Type II ATM Footprint Circuit Breaker Part No. (Amps) CB212-10 CB212-15 CB212-20 CB212-25 CB212-30 MMB Type I Wide ATM Footprint Circuit Breaker For GM Vehicles Part No. (Amps) OEM No. MMB-15 MMB-20 12135171 12135072 Mini Devices Transorb, resistor and diode vehicle-style electrical protection devices easily install in common ATM fuse holders. These circuit protection devices provide voltage and current limiting functionality to vehicle circuitry; and are designed for the on- and off-highway requirements of heavy trucks, RV, construction, agriculture, ATV and material handling equipment. • Transorb - Protects against voltage spikes. Clamp rating: 27Vdc. Power rating: 1500W • Resistor - Drops circuit voltage. Power rating: 5W. Resistance: 68W. • Diode - Prevents reverse current flow. Amp rating: 6A. Part No. Description CB22901-1.5 CB22902-68 CB22903-6 CB22903-6V Transorb voltage spike protector Resistor voltage drop device Diode reverse current protector Diode reverse current protector with wing key For product information and data sheets, visit www.cooperbussmann.com Consumer Aftermarket Catalog Automotive Circuit Breakers ATC Breakers CBB-30 Type II ATC Footprint Circuit Breaker CB221 and CB222 breakers are designed to fit ATC style fuse panels. Cooper Bussmann ATC breakers are the thinnest available in the aftermarket. These devices comply with SAE standard J553. Part No. (Amps) Blister Pack CBB-30 X CB227 complies with SAE J553 and SAE J1171 for ignition protection. Cooper Bussmann also offers three ATC-style breakers as replacement parts for specific OEM applications - ACB-20, CCB-25, and FCB-20. ACB-20 Type I ATC Footprint Circuit Breaker for GM Vehicles Part No. (Amps) Blister Pack OEM No. ACB-20 12040816 X CCB-25 Type I ATC Footprint Circuit Breaker For Chrysler Vehicles Part No. (Amps) OEM No. BP/CCB-25 4527053 CB221 Type I ATC Footprint Circuit Breakers Part No. (Amps) CB221-71/2 CB221-10 CB221-15 CB221-20 CB221-25 CB221-30 FCB-20 Type II ATC Footprint Circuit Breaker for Ford Vehicles CB222 Type II ATC Footprint Circuit Breakers Part No. (Amps) Part No. (Amps) BP/FCB-20 OEM No. D9AB-14526-BA CB222-10 CB222-15 CB222-20 CB222-25 CB222-30 CB223 Type III ATC Footprint Circuit Breakers Part No. (Amps) UCB breakers feature "snap-off" universal blades that can easily be sized to fit applications where fuse block spacing is tight, or the fuse terminal is recessed. CB223-71/2 CB223-10 CB223-15 CB223-20 CB223-25 CB223-30 CB227 Type III ATC Footprint Low-Profile Circuit Breakers Color Code Part No. (Amps) Tan Moss Green Brown Red Blue Yellow White Green CB227-5 CB227-6 CB227-71/2 CB227-10 CB227-15 CB227-20 CB227-25 CB227-30 UCB Type I ATC Footprint Circuit Breakers Color Code Part No. (Amps) Blister Tri-Lingual Pack Blister Plain Brown Red Blue Yellow Plain Green UCB-6 UCB-8 UCB-10 UCB-15 UCB-20 UCB-25 UCB-30 X X X X X For product information and data sheets, visit www.cooperbussmann.com X X 13 Consumer Aftermarket Catalog Automotive Circuit Breakers Maxi Breakers Heavy-Duty Breakers Identical in size to Maxi-style fuses. The only breakers on the market to match the Maxi's footprint and body dimensions. Used in many heavy-duty and truck applications. Use ring terminals to connect breaker into circuit. CB1911 Type I MAX Footprint Circuit Breakers Cooper Bussmann stud-type circuit breakers feature our patented fail-safe technology, and are available in styles: without bracket; with mounting bracket; waterproof, with mounting bracket and with combination blade and stud terminals. Complies with SAE standard J553. Part No. (Amps) CB1911-10 CB1911-15 CB1911-20 CB1911-25 CB1911-30 CB1911-35 CB1911-40 CB1911-50 CB123-B Type III 10-32 Stud-Mount Circuit Breakers with Crosswise Bracket and Cover Part No. (Amps) CB123-10B CB123-15B CB123-20B CB123-30B CB123-40B CB123-50B CB1921 Type II MAX Footprint Circuit Breakers Part No. (Amps) CB123-HB Type III 10-32 Stud-Mount Circuit Breakers with Lengthwise Bracket and Cover Part No. (Amps) CB1921-10 CB1921-15 CB1921-20 CB1921-25 CB1921-30 CB123-10HB CB123-15HB CB123-20HB CB123-30HB CB123-40HB CB123-50HB CBC Type I 10-32 Stud-Mount Circuit Breakers Part No. (Amps) Glass Tube Breakers CBF Type II Circuit Breakers For Use In Glass Tube Fuse Holders and Blocks CBF circuit breakers can be used to replace glass fuses in 1/4” x 11/4” small dimension fuse blocks. Part No. (Amps) CBF-6 CBF-10 CBF-15 CBF-20 CBF-25 CBF-30 CBF-35 CBF-40 14 Blister Pack X CBC-8 CBC-10 CBC-15 CBC-20 CBC-25 CBC-30 CBC-35 CBC-40 CBC-50 CBC-B Type I 10-32 Stud-Mount Circuit Breakers with Crosswise Bracket Part No. (Amps) Blister Pack CBC-8B CBC-10B CBC-15B CBC-20B CBC-25B CBC-30B CBC-35B CBC-40B CBC-50B X X X X X X Tri-Lingual Blister X For product information and data sheets, visit www.cooperbussmann.com Consumer Aftermarket Catalog Automotive Circuit Breakers Quick-Connect Breakers CBC-BWP Type I 10-32 Stud-Mount Weatherproof Circuit Breakers Used in trucks, RVs, boats, buses, etc. offered with 1/4" quick-connect or 90° bent screw terminals. Part No. (Amps) CBC-20BWP CBC-30BWP CBT-M Type II Circuit Breakers For Mack Trucks with 1 /4" Blades on 1" Centers CBC-HB Type I 10-32 Stud-Mount Circuit Breakers with Lengthwise Bracket Part No. (Amps) CBT-10M CBT-15M CBT-20M CBT-25M CBT-30M Blister Pack CBC-10HB CBC-15HB CBC-20HB CBC-25HB CBC-30HB CBC-40HB CBC-50HB Part No. (Amps) X X X X CBT-N Type II Circuit Breakers For Navistar Trucks with 1 /4" Blades on 1.08" Centers Part No. (Amps) CBP-BA Type I 10-32 Stud-Mount Circuit Breakers with Crosswise Bracket Part No. (Amps) CBP-20BA CBP-25BA CBP-30BA CBP-40BA CBP-50BA CBT-10N CBT-15N CBT-20N CBT-25N CBT-30N CBU Type I Circuit Breakers with 1/4" Quick-Connect Terminals on 0.99" Centers (30B with crosswise bracket) Panel-Mount Breakers Part No. (Amps) Used in trucks, RVs, boats, buses, etc. offered with 1/4" quick-connect or 90° bent screw terminals. CB174 Type III Circuit Breakers with 1 /4" Quick-Connect Terminals CBU-6 CBU-30B Part No. (Amps) CB174-8 CB174-10 CB174-15 CB174-20 CB174-25 CB174-30 CBU-30B CBU-6 CB174B Type III Circuit Breakers with 90° 5-32 Screw Terminals Part No. (Amps) CB174B-10 CB174B-15 CB174B-20 CB174B-25 CB174B-30 CB174B-40 For product information and data sheets, visit www.cooperbussmann.com 15 Consumer Aftermarket Catalog Automotive Circuit Breakers Marine-Rated Circuit Breakers High Amp Circuit Breakers These high amp circuit breakers are typically used in auxiliary and accessory circuits for trucks, buses, RVs and marine applications. All high amp circuit breakers comply with the SAE J1117 standard for ignition protection and have applications in battery charger systems and DC audio systems. Offered in flush-mount or panel-mount (see chart for amps available). CB181F Type I High Amp Waterproof Circuit Breakers with SEMS Nuts Installed CB181F-110 CB181F-120 CB181F-135 CB181F-150 CB184F Type III High Amp Waterproof Manual Reset Circuit Breakers with SEMS Nuts Installed Part No. (Amps) CB184F-25 CB184F-30 CB184F-35 CB184F-40 CB184F-50 CB184F-60 CB184F-70 Part No. (Amps) CB187F-25 CB187F-30 CB187F-35 CB187F-40 CB187F-50 CB187F-60 CB187F-70 Part No. (Amps) CB181F-60 CB181F-70 CB181F-80 CB181F-90 CB181F-100 Specifically designed to meet the needs of marine applications, the CB187F and CB187P offer 5kA interrupting ratings and ignition protection per ABYC E-11. Usable as an ON/OFF switch (capable of withstanding 3000 on/off cycles @48Vdc), they have corrosion resistant plating on 5/16-18 copper terminals. CB187F Type III Marine-Rated Surface-Mount Manual Reset Circuit Breaker with Switch Function and Nuts/Lock Washers Installed CB184F-80 CB184F-90 CB184F-100 CB184F-110 CB184F-120 CB184F-135 CB184F-150 CB187F-80 CB187F-90 CB187F-100 CB187F-110 CB187F-120 CB187F-135 CB187F-150 CB187P Type III Marine-Rated Panel-Mount Manual Reset Circuit Breaker with Switch Function and Nuts/Lock Washers Installed Part No. (Amps) CB187P-25 CB187P-30 CB187P-35 CB187P-40 CB187P-50 CB187P-60 CB187P-70 CB187P-80 CB187P-90 CB187P-100 CB187P-110 CB187P-120 CB187P-135 CB187P-150 CB185 Type III High Amp Switchable, Waterproof, Flush-Mount Manual Reset Circuit Breakers with SEMS Nuts Installed Part No. (Amps) Blister Pack CB185-25 CB185-30 CB185-35 CB185-40 CB185-50 CB185-60 CB185-70 CB185-80 CB185-90 CB185-100 CB185-110 CB185-120 CB185-135 CB185-150 CB251 Type I Ignition Protected Weatherproof Panel-Mount Manual Reset Circuit Breaker with SEMS Nuts Installed, 32Vdc Part No. (Amps) CB251-10 CB251-15 CB251-20 CB251-25 X X X X X X X CB185P Type III High Amp Switchable, Panel Mount Manual Reset Circuit Breakers with SEMS Nuts Installed 16 CB255 Type III Ignition Protected Weatherproof Panel-Mount Manual Reset Circuit Breaker with “Push-to-Trip” Option and SEMS Nuts Installed, 32Vdc Part No. (Amps) Part No. (Amps) CB185P-25 CB185P-30 CB185P-35 CB185P-40 CB185P-50 CB185P-60 CB185P-70 CB251-30 CB251-35 CB251-40 CB251-50 CB185P-80 CB185P-90 CB185P-100 CB185P-110 CB185P-120 CB185P-135 CB185P-150 CB255-10 CB255-15 CB255-20 CB255-25 CB255-30 CB255-35 CB255-40 CB255-50 For product information and data sheets, visit www.cooperbussmann.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Eaton: CB1921-20 CB181F-90 CB181F-60 CB185-120 CB185-100 CB185-150 CB185-70 CB185-50 CB1921-30 CB221-10 CB221-30 CB221-15 CB185P-70 CB185P-50 CB185P-60 CB181F-120 CB223-15 CB223-25 CB181F150 CB223-10 CB223-30 CB181F-135 CB221-25 CB221-20 CB1911-50 CB1911-30 CB185P-150 CB1911-20 CB1911-40 CB185-80 CB185-60 CB185P-120 CB181F-100 CB181F-80 CB211-30 CB211-10 CB211-20 CB21125 CB211-15 CB185P-100 UCB-30 UCB-20 UCB-10 CB185P-110 CB227-20 BK/UCB-15 CB174B-20 CB181F110 CB181F-70 CB184F-100 CB184F-110 CB184F-120 CB184F-135 CB184F-150 CB184F-30 CB184F-40 CB184F-50 CB184F-60 CB184F-70 CB184F-80 CB184F-90 CB185P-135 CB185P-25 CB185P-30 CB185P-35 CB185P-40 CB185P-50-03 CB185P-80 CB185P-90 BK/CB181F-80 CBP-25BA CB1921-10 CB174B-40 CB187P90 CB222-10 BK/CB1911-10 CBU-6 BK/CB123-20HB CB174-10 BK/CB174B-20 CBC-50 CB187F-100 CB187F35 CB123-15B CB1911-10 BK/CBC-50 BK/CB174-15 BK/CB174B-35 CB174-25 CBC-35B CBC-20 FCB-20 BK/CB185-150 CB187F-60 CBP-10B CBC-30BWP BK/CB123-50HB CB185-25 CB222-25 BK/CB174B-25
BK/CB1911-10 价格&库存
很抱歉,暂时无法提供与“BK/CB1911-10”相匹配的价格&库存,您可以联系我们找货
