SD00-S
SD00-S
    EATON(伊顿)
    SCREWNH00SINGLEPOLESILVER
SD00-S 数据手册
Technical Data 10163 Effective June 2018 Supersedes October 2017 BUSSMANN SERIES NH Bases Product description Eaton’s Bussmann™ series NH Bases have been designed with thermoplastic bodies DIN-Rail and/or screw mounting (size 4 screw mounting only). This range comes with accessories including phase barriers: IP20 finger safe protection kits (IEC only) and neutral links. Microswitch also available for remote signaling of fuse link operation. Standard features • Complies with IEC 60269-1 and 2 fuse system A (NH Base), manufacturers type test certificates of compliance available. • 3-pole integral NH00 Base available with reduced width • Clip-in phase barriers, terminal shrouds and fuse covers available • Vibration tested to IEC 60068-2-6 for marine use Technical Data 10163 NH Bases Effective June 2018 Catalogue symbol • 1-pole DIN-Rail and screw mounting: SD(size)-D • 1-pole screw mounting only: SD(size)-S • 3-pole DIN-Rail and screw mounting: TD(size)-D • 3-pole Integral DIN-Rail and screw mounting: TD00-DxI (see catalogue numbers for details) Technical data Rated voltage: • • 690 V a.c. IEC • 1000 V a.c. UL for SD1-D only • Rated current: 160 to 1600 A • Rated for fuse links with breaking capacity of 120 kA Standard/Approvals • IEC 60269-1 and 2 • VDE 0636-1 and 2 Packaging • 1-pole: 3 • 3-pole and SD4: 1 Technical data SD00-D SD1-D TD00-D TD1-D TD00-DI Glass filled PBT Silver plated copper Zinc clear plated steel Fuse base catalogue numbers Base Contacts Screw, nuts and washers Derating temperature factors for maximum current SD4-S SD4-S1600 1 1 1 1 1 1 40°C 0.95 0.95 0.95 0.95 0.95 0.95 50°C 0.85 12W 0.85 32W 0.85 45W 0.85 60W 0.85 110W 0.85 145W       M8 10N•m M10 32N•m M10 32N•m M12 32N•m M16 56N•m M16 56N•m                   Terminal screw Maximum tightening torque terminal screw DIN-Rail Fixing Screw Fuse operated signal Operating temperature range Storage temperature range 2 SD3-D TD3-D  35°C Maximum power acceptance IP20 finger safe protection kits (IEC only) With microswitch 16A/250V SD2-D TD2-D EATON www.eaton.com -20 to 70°C -40 to 80°C Technical Data 10163 NH Bases Effective June 2018 1-pole and 3-pole non integral NH Bases - Catalogue numbers Compatible NH Fuse link body size 00 Poles 1-pole Current (Amps) 160 DIN-Rail and screw mounting SD00-D Screw mounting only SD00-S Pack quantity 3 1 3-pole 1-pole 160 250 TD00-D SD1-D N/A SD1-S 1 3 3-pole 250 TD1-D N/A 1 2 1-pole 400 400 SD2-D SD2-DD* SD2-S N/A 3 3 3-pole 400 400 TD2-D TD2-DD* N/A N/A 1 1 3 1-pole 630 SD3-D* SD3-S 3 4 3-pole 1-pole 630 1250 TD3-D* N/A N/A SD4-S 1 1 1600 N/A SD4-S1600 1 Compatible fuse links 400/500/690 V NH gG and aM fuse links *Double fuse contact clips 1-pole and 3-pole non integral NH base - Catalogue numbers structure Poles SD = Single pole Compatible NH Fuse links body size 00 = Compatible for NH fuse links body size 00 TD = Triple pole 1 = Compatible for NH fuse links body size 1 2 = Compatible for NH fuse links body size 2 Mounting type D = DIN-Rail and screw mounting DD = Double fuse contact clips S = Screw mounting only S1600 = Screw mounting only, 1600 A 3 = Compatible for NH fuse links body size 3 4 = Compatible for NH fuse links body size 4 (Single pole only) For example catalogue number SD2-D represents a 1-pole SD NH Fuse base, suitable for a NH fuse link body size 2 fuse link, S screw mounting only 3-pole Integral NH Base parts - Catalogue numbers Catalogue numbers TD00-DI TD00-DCI TD00-DPI Line side mounting Screw mounting holes Clinch nut Pressure plate Compatible NH Fuse Load side mounting link body size Screw mounting holes 00 Clinch nut Pressure plate TD00-DBI TD00-DCPI TD00-DCBI TD00-DPBI 70 mm fixed box lug Clinch nut Clinch nut Pressure plate 70 mm fixed box lug Pressure plate 70 mm fixed box lug 70 mm fixed box lug Poles 3-pole Current (Amps) 160 Pack quantity 1 Compatible NH fuse links 400/500/690 V NH gG and aM fuse links 3-pole Integral NH Base parts - Catalogue numbers structure Poles TD = Triple pole Compatible NH Fuse links size 00 = Compatible for NH fuse links body size 00 Line side mounting/ Load side mounting I = Integral base screw mounting/screw mounting C = Clinch nut/clinch nut P = Pressure plate/pressure plate B = 70 mm fixed box lug/70 mm fixed box lug CP = Clinch nut/pressure plate CB = Clinch nut/70 mm fixed box lug PB = Pressure plate/70 mm fixed box lug Integral NH Base I = Integral NH Base For example catalogue number TD00-CPI represents a 3-pole TD NH Fuse base, suitable for a NH fuse link body size 00, with C clinch nut load side mounting and P pressure plate load side mounting, I integral base EATON www.eaton.com 3 Technical Data 10163 NH Bases Effective June 2018 Solid links catalogue numbers NH fuse link body size NH00 NH1 NH2 Current (Amps) 160 250 400 Catalogue numbers SDL-00 SDL-1 SDL-2 Pack quantity 3 3 3 NH3 630 SDL-3 3 Solid link Accessories Fuse extraction handle NH fuse link body size NH00-3 Catalogue numbers FEH Current (Amps) 160 - 630 Pack quantity 1 Fuse extraction handle Shroud kits Fuse base range SD00 NH fuse link Current body size (Amps) NH00 160 Catalogue numbers SD00-SK SD1 SD2 SD3 NH1 NH2 NH3 SD12-SK SD12-SK SD3-SK 250 400 630 Description Kit includes 2 shrouds and 1 fuse cover Shroud kit Phase barrier kit NH fuse link body size NH00 NH1 NH2 NH3 4 Current (Amps) 160 250 400 630 Catalogue numbers SD00-PB SD12-PB SD12-PB SD3-PB Pack quantity 1 1 1 1 EATON www.eaton.com Description 2-Phase barriers 2-Phase barriers and 2 ganging links Phase barrier Ganging link Technical Data 10163 NH Bases Effective June 2018 Accessories IP Protection Kits NH fuse link Current body size (Amps) NH00 160 Catalogue numbers TD00-IP20 Fuse cover 3 Shroud 6 Phase barrier 2 Ganging link 1 TD00-IP20I TD00-IP20IC NH1 250 TD1-IP20 NH2 NH3 400 630 TD2-IP20 TD3-IP20 Integral kit 3 1 3 TD00-IP20 6 TD00-IP20I 2 2 TD00-IP20IC Description Triple pole protection kit for TD00-D with shrouds, fuse covers and phase barriers Integral triple pole protection kit for TD00-DI with molded shrouds and phase barriers Integral triple pole protection kit for TD00-DI with fuse covers and molded shrouds and phase barriers Triple pole protection kit with terminal shrouds, fuse cover phase barriers and ganging links TD(size 1 to 3)-IP20 Microswitch Catalogue numbers Pack quantity BVL50 1 170H0236 12 Ratings 5 A 250 V a.c. 2 A 250 V a.c. 170H0238 2 A 250 V a.c. 12 Microswitch suitable for the following NH fuse links: • 400 Volts gG/gL • 500 Volts gG/gL and aM • 690 Volts gG/gL and aM. BVL50 Note: Microswitches fit onto the fuse gripping lugs and are applicable to all Bussmann series NH fuses. 5 EATON www.eaton.com 170H0236 Technical Data 10163 NH Bases Effective June 2018 Dimensions (mm) 1-pole, size 00 NH fuse link body size NH00 Pole 1-pole A 120 B 102 C 35.5 D 20 E 56 F 24 G 51 H M8x20 I 25 J 8 Dimensions (mm) 1-pole, sizes 1, 2 and 3 Fuse body size NH1 NH2 NH3 Poles/Type 1-pole A 199 B 175 C 56 D 35 E 79 F 37 G 78 H M10x25 I 25 J 10 K 30 1 pole 1-pole double clip 1-pole 224 223 239 199 199 209 56 56 56 35 35 36 79 82 82 37.5 37 37.5 86 79 88 M10x25 M10x25 M12x30 25 25 25 10 10 10 30 30 30 EATON www.eaton.com 6 Technical Data 10163 NH Bases Effective June 2018 Dimensions (mm) 1-pole, size 4 NH fuse link body size Poles/Type 1-pole 1250A NH4 1-pole 1600A A 295 B 255 C 90 D 52 E 105 F 47 G 122 H M16x40 I 30 J 14 K 40 L 150 M 92 N M12x40 295 255 90 60 105 50 125 M16x40 30 14 40 150 92 M12x40 Dimensions (mm) 3-pole, size 00 NH fuse link body size Poles/Type NH00 3-pole 7 A 120 EATON www.eaton.com B 102 C 35.5 D 20 E 56 F 24 G 51 H M8x20 I 25 J 8 K - L 103.5 M 34 N 146 P 89 Technical Data 10163 NH Bases Effective June 2018 Dimensions (mm) 3-pole, sizes 1, 2 and 3 NH Fuse link body size NH1 Poles/Type 3-pole A 199 B 175 C 56 D 35 E 79 F 37 G 78 H M10x25 I 25 J 10 K 30 L 188 M 66 N 245 P 125.5 NH2 3-pole 3-pole double clip 224 223 199 199 56 56 35 35 79 82 37.5 37 86 79 M10x25 M10x25 25 25 10 10 30 30 188 188 66 66 245 245 125.5 125.5 NH3 3-pole 239 209 56 36 82 37.5 88 M12x30 25 10 30 221 82.5 260 137.5 Dimensions (mm) integral 3-pole, size 00 NH fuse link body size Poles/Type NH00 3-pole Integral A 120 B 102 C - D 20 E 56 F 24 G 51 H I M8x20 - J K 7.5x10 63.5 L 97 M 32.3 N 146 EATON www.eaton.com P 90 8 Technical Data 10163 NH Bases Effective June 2018 Fixings dimensions (mm) for integral 3-pole NH Base ƒ ƒ  ƒ “ “     Pressure plate ƒ ƒ  ƒ “  “     Box lug  “  “ ƒ ƒ  ƒ           “  “   $ $ Clinch nut Eaton EMEA Headquarters Route de la Longeraie 7 1110 Morges, Switzerland Changes to the products, to the information contained in this document, and to prices are reserved; so are errors and omissions. Only order confirmations and technical documentation by Eaton is binding. Photos and pictures also do not warrant a specific layout or functionality. Their use in whatever form is subject to prior approval by Eaton. The same applies to Trademarks (especially Eaton, Moeller, and Cutler-Hammer). The Terms and Conditions of Eaton apply, as referenced on Eaton Internet pages and Eaton order confirmations. Eaton Electrical Products Limited Melton Road Burton-on-the-Wolds Leicestershire, LE12 5TH United Kingdom © 2017 Eaton All Rights Reserved PDF Only Publication No. 10163 June 2018 Eaton is a registered trademark. All other trademarks are property of their respective owners.
SD00-S
1. 物料型号:文档提供了多种NH基座的型号,包括1极和3极的DIN轨道和/或螺丝安装型号,以及仅螺丝安装的型号。
2. 器件简介:NH基座设计有热塑性体,适用于DIN轨道和/或螺丝安装,包括尺寸4的螺丝安装。这些基座配备了包括相位屏障在内的配件,IP20指触安全保护套件(仅IEC),中性链接,以及用于远程信号传输的微型开关。
3. 引脚分配:文档中没有明确提到引脚分配,但提供了不同型号基座的接线端子和安装细节。
4. 参数特性:包括额定电压(690V AC IEC和1000V AC UL,仅SD1-D型号),额定电流范围从160到1600安培,以及适用于额定断路容量为120kA的保险丝链接。
5. 功能详解:文档详细描述了NH基座的标准特性,包括符合IEC 60269-1和2的保险丝系统A(NH基座),振动测试符合IEC 60068-2-6的海上使用标准。
6. 应用信息:NH基座适用于多种电流和电压规格,文档提供了兼容的保险丝链接型号和包装数量。
7. 封装信息:提供了不同型号基座的尺寸和安装细节,以及整体安装的固定尺寸。
SD00-S 价格&库存
很抱歉,暂时无法提供与“SD00-S”相匹配的价格&库存,您可以联系我们找货
