37157
37157
    GREENLEECOMMUNICATIONS(格林利)
37157 数据手册
ARBOR,HOLESAW SMALL (PKGD, 37157) Arbors with Replacement High-Speed Steel Pilot Drill Bits Cat No: 37157 UPC No: 783310371571 Description • • • • • The best arbor in the industry ensures a solid connectionwithout any gaps or wobbling Arbors include replaceable, high-speed steel pilot drill Pilot drills have unique split-point tip design Use with Greenlee bimetal hole saws, recessed light holesaws and carbide-grit hole saws (carbide-tipped pilot drillsold separately) Can be used with Greenlee #901 or #904 bit extensions Specifications • • • • • • • Application : Use With Greenlee Bimetal Hole Saws, Recessed Light Hole Saws And Carbide Grit Hole Saws (Carbide-Tipped Pilot Drill Sold Separately), Can Be Used With Greenlee No 901 Or 904 Bit Extensions, 1-1/4 IN - 2.000 IN (31.800 - 50.800 MM) Hole Saws Material : High Speed Steel Pilot Drill Bit Minimum Chuck Size : 1/4 IN (6.400 MM) Package : Standard Pack Shank Diameter : 1/4 IN (6.400 MM) Type : Round With 3 Flats Weight : 0.200 LB (91.000 GM)
37157 价格&库存
很抱歉,暂时无法提供与“37157”相匹配的价格&库存,您可以联系我们找货
