NFTA36
NFTA36
    EATON(伊顿)
NFTA36 数据手册
MAGNUM ® SPECIFICATIONS High Density Design: Up to 48 circuits per foot Clamping Collar: Secures wires Large, Captive, Wire-Ready Screws: Speeds assembly Snap-on Installation to DIN Rail: Fast, easy assembly Fully Shielded Construction: 600V spacings Unique One-Piece Construction: Increases reliability Thermoplastic Moldings: Strong and impact resistant Material: UL Recognized 94V2 thermoplastic Collars: Heat treated stainless steel Terminals: Tin plated copper alloy Screws: Zinc plated steel Agency Information: UL/CSA; CE Certified Power Distribution Blocks WIRE MANAGEMENT PRODUCTS NDNF1 Single pole fuseholder accepts 13/32" x 1-1/2" fuses NDN1/NDN111 Heavy-duty 90 Amp block Base & Rail Mount Connectors Euro-MAG Series PCB – Spring Clamp Single & Double Row Filtered Connectors Series NDN Rail Mount Terminal Blocks 35mm DIN Rail Compatible NDN63 Accepts wires larger than standard control circuits NDN3 Space saving 3-pole unit NDNA200 Universal aluminum 35mm DIN mounting rail NDNV4 High Density 48 circuits per foot Series NDN Terminal Block Accessories NDNA 35mm DIN Rail Aluminum NDNA 100 1 meter NDNA 200 2 meters 120 NDNAS 35mm DIN Rail End Stop NFTA C-Rail Aluminum Lengths to 72" NRA C-Rail Low Profile No Flange Aluminum Lengths to 37-1/2" Inches (Millimeters) SOA72 72" Long Stand-Off Channel For C-Rail MASKING TAPE See Series Specifications JUMPERS See Series Specifications Rail Mount Terminal Blocks 1.50 (38.10) 1.67 (42.41) 1.45 (36.83) 1.17 (29.71) NDN1 1.32 (33.68) 1.71 (43.48) Dovetail Option Base & Rail Mount Connectors SPECIFICATIONS: Rating: 90A, 600V Center Spacing: .635" (16.13 mm) Number Of Poles: 1 Circuits Per Foot: 18 Wire Range: AWG #2-18 CU Screw Size: #1/4-28 Mounting Options: 35mm DIN rail, C-rail * Dove-tail option is available for mounting side-by-side. Order part no. NDN1-A Marking Tape: MT12-1/2 Torque Rating: 32 in-lb Operating Temperature: 105°C .59 (14.99) 1.43 (36.31) Mtg. holes .18 (4.57) dia. .28 (7.11) c'bores 1.46 (37.13) 1.71 (43.48) Dovetail Option Power Distribution Blocks NDN111 .62 (15.75) 1.87 (47.50) 1.44 (36.57) 121 WIRE MANAGEMENT PRODUCTS SPECIFICATIONS: Rating: 90A, 600V; UL/CSA Center Spacing: .635" (16.13 mm) Number Of Poles: 3 Circuits Per Foot: 18 Circuit Jumper: JN1, 2 circuits Wire Range: AWG #2-18 CU Screw Size: #1/4-28 Mounting Options: 35mm DIN rail, C-rail, Base Mount * Dove-tail option is available for mounting side-by-side. Order part no. NDN111-A Marking Tape: MT12-1/2 Torque Rating: 32 in-lb Operating Temperature: 105°C Euro-MAG Series PCB – Spring Clamp SPECIFICATIONS: Rating: 65A, 600V; UL/CSA Center Spacing: .375" (9.52 mm) Number Of Poles: 3 Circuits Per Foot: 30 Circuit Jumper: JN3, 2 circuits Wire Range: AWG #6-18 CU Screw Size: #10-32 Mounting Options: 35mm DIN rail, C-rail Marking Tape: MT12-1/2 Torque Rating: 35 in-lb Operating Temperature: 105°C Single & Double Row Filtered Connectors NDN63 MAGNUM ® Euro-MAG Series PCB – Spring Clamp Single & Double Row Filtered Connectors Rail Mount Terminal Blocks NDNV4 SPECIFICATIONS: Rating: NDNV4 30A, 600V; UL/CSA Center Spacing: .250" (6.35mm) Number Of Poles: 4 Circuits Per Foot: 48 Circuit Jumper: JN4, 4 circuits Wire Range: AWG #10-22 CU Screw Size: #6-32 Mounting Options: 35mm DIN rail, C-rail Marking Tape: MTC6 Torque Rating: 18 in-lb Operating Temperature: 105°C 1.00 (25.40) Marking Tape Power Distribution Blocks Base & Rail Mount Connectors 1.67 1.47 1.23 (42.41) (37.33) (31.24) NDN3 SPECIFICATIONS: Rating: 30A - field wiring: 40A - factory wiring 600V; UL/CSA Center Spacing: .300" (7.62 mm) Number Of Poles: 3 Circuits Per Foot: 38 Circuit Jumper: JNDN3, 2 circuits Wire Range: AWG #10-22 CU Screw Size: #6-32 Mounting Options: 35mm DIN rail, C-rail Marking Tape: MT12-1/2 Torque Rating: 18 in-lb Operating Temperature: 105°C WIRE MANAGEMENT PRODUCTS 1.47 (37.33) 1.67 (42.41) .94 (23.87) 122 1.31 (33.27) 1.34 (34.04) Rail Mount Terminal Blocks 2.40 (60.96) 1.09 (27.68) .88 (22.35) Euro-MAG Series PCB – Spring Clamp SPECIFICATIONS: Rating: 5A, 600V; UL/CSA 20A, 300V; UL/CSA Center Spacing: .197" (5.00 mm) Number Of Poles: 12 Circuits Per Foot: 60 Circuit Jumper: JN512, 12 circuits Wire Range: AWG #12-22 CU Screw Size: #4-48 Mounting Options: C-rail, 15mm DIN rail Marking Tape: AT512 Torque Rating: 12 in-lb Operating Temperature: 105°C Single & Double Row Filtered Connectors N512 NFT2 .07 (1.78) .60 (15.44) 1.29 (32.94) .93 (23.80) 1.68 (42.82) .36 (9.14) 1.23 (31.34) Base & Rail Mount Connectors SPECIFICATIONS: Rating: 40A, 600V; UL/CSA; 55A Factory Wired Center Spacing: .281" (7.13 mm) Number Of Poles: 2 Circuits Per Foot: 38 Circuit Jumper: JN2, 2 circuits Wire Range: AWG #8-22 CU Screw Size: #8-32 Mounting Options: C-rail Marking Tape: MT12-1/2 Torque Rating: 18 in-lb Operating Temperature: 105°C .65 (16.51) 1.18 (29.97) 1.29 (32.94) 1.23 (31.37) 123 WIRE MANAGEMENT PRODUCTS SPECIFICATIONS: Rating: 40A, 600V; UL/CSA 55A Factory Wired Center Spacing: .390" (9.91 mm) Number Of Poles: 3 Circuits Per Foot: 28 Circuit Jumper: JN3, 2 circuits Wire Range: AWG #8-22 CU Screw Size: #8-32 Mounting Options: C-rail Marking Tape: MT12-1/2 Torque Rating: 18 in-lb Operating Temperature: 105°C Power Distribution Blocks NFT3 MAGNUM ® Base & Rail Mount Connectors Euro-MAG Series PCB – Spring Clamp Single & Double Row Filtered Connectors Rail & Base Mount Terminal Blocks NC3 SPECIFICATIONS: Rating: 175A, 600V; UL/CSA Center Spacing: 1.06" (26.92 mm) Number Of Poles: 3 Circuits Per Foot: 11 Wire Range: 2/0-#14 CU/AL Screw Size: 5/16-24 Mounting Options: C-rail, Base Mountl Marking Tape: MT12-1/2 Torque Rating: 45 in-lb Operating Temperature: 105°C 3.12 (79.38) 1.75 (44.45) 1.75 (44.45) 1.25 (31.75) .250 x .190" mtg. slots NSE3 SPECIFICATIONS: Rating: 115A, 600V; UL/CSA Center Spacing: 1.06" (26.92 mm) Number Of Poles: 3 Circuits Per Foot: 11 Circuit Jumper: JNSE3, 2 circuits Wire Range: For use with wire crimped to ring terminal Screw Size: #1/4-28 Mounting Options: C-rail, Base Mount Marking Tape: MT12-1/2 Torque Rating: 32 in-lb Operating Temperature: 105°C 1.25 (31.75) .250 x .190 mtg. slots 1.75 (44.45) 1.53 (38.86) WIRE MANAGEMENT PRODUCTS Power Distribution Blocks 3.12 (79.24) NSS3 SPECIFICATIONS: Rating: 30A, 600V; UL/CSA Center Spacing: .385" (9.77 mm) Number Of Poles: 3 Circuits Per Foot: 28 Circuit Jumper: JNSS3, 2 circuits Wire Range: For use with wire crimped to ring terminal Screw Size: #6-32 Mounting Options: C-rail Marking Tape: MT12-1/2 Torque Rating: 12 in-lb Operating Temperature: 105°C 124 1.24 (31.50) 1.25 (31.75) 1.32 (33.73) Depluggable Rail Mount Terminal Blocks 1.25 (31.75) .59 (14.98) 1.25 (31.75) 1.79 (45.64) 1.25 (31.75) 1.85 (46.99) Euro-MAG Series PCB – Spring Clamp SPECIFICATIONS: Rating: 40A, 600V; UL/CSA Center Spacing: .390" (9.91 mm) Number Of Poles: 3 Circuits Per Foot: 28 Circuit Jumper: JN3, 2 circuits Wire Range: AWG #8-22 CU Screw Size: #8-32 Mounting Options: C-rail, Stackable Marking Tape: MT12-1/2 Torque Rating: 18 in-lb Operating Temperature: 105°C Single & Double Row Filtered Connectors PLU3 PLU1 Series SPECIFICATIONS: Rating: 70A, 600V; UL/CSA Center Spacing: .625" (15.88 mm) Number Of Poles: 1-3 PLU1 (1 pole) PLU11 (2 pole) PLU111 (3 pole) Circuits Per Foot: 19 Circuit Jumper: JN1, 2 circuits Wire Range: AWG #4-18 CU Screw Size: #1/4-28 Mounting Options: C-rail, Stackable Marking Tape: MT12-1/2 Torque Rating: 32 in-lb Operating Temperature: 105°C 1.85 (46.99) 1.48 (37.59) 1.87 (47.49) Base & Rail Mount Connectors 1.25 (31.75) 1.93 (49.12) 1.48 (37.64) .625 (15.88) 2.44 (62.10) .43 (11.10) 1.30 (33.00) 125 WIRE MANAGEMENT PRODUCTS SPECIFICATIONS: Rating: 45A*, 600V; UL/CSA *45A rating achieved with ring terminal crimped to wire. Center Spacing: .625" (15.88 mm) Number Of Poles: 1-3 PSU1 (1 pole) PSU11 (2 pole) PSU111 (3 pole) Circuits Per Foot: 19 Wire Range: For use with crimp on connectors only. Screw Size: #10-32 Mounting Options: C-rail, Stackable Marking Tape: MT12-1/2 Torque Rating: 24 in-lb Operating Temperature: 105°C Power Distribution Blocks PSU1 Series Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Eaton: NDNF1-BK PLU111-WH NC3-BK NDNF1-WH NDN111-BK NDNV4-WH PLU3-WH NFT3-WH NDN111-WH PLU1-WH NC3-WH NDN3-YE NDNV4-YE NDN63-YE NFTA36 NDN1-WH NFTA72 NDN63-WH NFT2-WH NDNA200 NDN3-WH N512-BK PLU11-WH
NFTA36 价格&库存
很抱歉,暂时无法提供与“NFTA36”相匹配的价格&库存,您可以联系我们找货
NFTA36
    • 10+159.8082110+20.70076
