ABC-1/10
ABC-1/10
    EATON(伊顿)
    ABC-1/10
ABC-1/10 数据手册
1/4" x 1-1/4" Fuses ABC Series, Fast Acting, Ceramic Tube Description • Fast-acting, ceramic tube • Optional leaded version available • 1/4 x 1-1/4 (6.3mm x 32mm) physical size • Ceramic tube, nickel-plated brass endcap construction • UL Listed product meets standard 248-14 ELECTRICAL CHARACTERISTICS % of Amp Rating Opening Time 110% 4 Hours Minimum 135% 60 Minutes maximum 200% 120 Seconds Maximum Approvals • UL Listed Guide & File numbers (ABC 1/4 - 15A): JDYX & E19180. • UL Recognition Guide & File numbers (ABC 20 - 30A): JDYX2 & E19180. • CSA Certification Record No: 053787 C 000 & Class No: 1422 01 & 1422 30. Environmental Data • Shock: 1/4A and 1/2A – MIL-STD-202, Method 213, Test Condition I; 1A thru 30A – MIL-STD-202, Method 207, (HI Shock) • Vibration: 1/4A thru 30A – MIL-STD-202, Method 204, Test Condition C (Except 5g, 500HZ) Ordering • Specify product code, option code and packaging code Dimensions (mm⁄in) Drawing Not to Scale SPECIFICATIONS Product Code ABC-1/4 ABC-1/2 ABC-3/4 ABC-1 ABC-1-1/2 ABC-2 ABC-2-1/2 ABC-3 ABC-4 ABC-5 ABC-6 ABC-7 ABC-8 ABC-10 ABC-12 ABC-15 ABC-20 ABC-25 ABC-30 Voltage Rating AC DC 250V 125V 250V 125V 250V 125V 250V 125V 250V 125V 250V 125V 250V 125V 250V 125V 250V 125V 250V 125V 250V 125V 250V 125V 250V 125V 250V 125V 250V 125V 250V 125V 250V 125V 125V 125V 125V 125V AC Interrupting Rating 250V 125V 35A 10000A 35A 10000A 35A 10000A 35A 10000A 100A 10000A 100A 10000A 100A 10000A 100A 10000A 200A 10000A 200A 10000A 200A 10000A 200A 10000A 200A 10000A 200A 10000A 750A 10000A 750A 10000A 400A 1000A 1000A 1000A DC Interrupting Rating 125V 75V 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 400A 1000A 400A 1000A Typical DC Cold Resistance** (ohms) 3.000 0.788 0.303 0.197 0.1175 0.0755 0.05875 0.0435 0.02975 0.0286 0.02315 0.0183 0.0146 0.01205 0.0068 0.005425 0.00366 0.00263 0.002225 Typical Melting I2t† AC 0.02 0.19 0.8 1.4 2.9 4.2 8.53 19.5 29.1 16.4 31.6 73.2 111.9 215.6 129.6 200.2 550.8 839.3 1,429 ** DC Cold Resistance (Measured at ≤10% of rated current) † Typical Melting I2t (A2Sec) (I2t was measured at listed interrupting rating and rated voltage. Measured at 70% to 80% power factor on AC) ‡ Typical Voltage Drop (Voltage drop was measured at 25°C±3°C ambient temperature at rated current) Typical Voltage Drop‡ 3.25 0.51 0.42 0.35 0.35 0.25 0.26 0.25 0.25 0.23 0.24 0.20 0.17 0.15 0.11 0.12 0.13 0.12 0.14 1/4" x 1-1/4" Fuses ABC Series, Fast Acting, Ceramic Tube TIME CURRENT CURVE 15 20 25 30 8 10 5 3 2 1 CURRENT IN AMPERES CURRENT IN AMPERES OPTION CODE Option Code B V Description Board Washable - Hermetically sealed to withstand aqueous cleaning Axial leads - brass overcaps with copper and nickel flash, plated in tin lead PACKAGING CODE Packaging Code BK BK1 BK8 OC-2542 10/01 © Cooper Electronic Technologies 2001 Description 100 pieces of fuses packed into a cardboard carton with flaps folded 1,000 pieces of fuses packed into a cardboard carton with flaps folded 8,000 pieces of fuses packed into a cardboard carton with flaps folded Visit us on the Web at www.cooperET.com 3601 Quantum Boulevard Boynton Beach, Florida 33426-8638 Tel: +1-561-752-5000 Toll Free: +1-888-414-2645 Fax: +1-561-742-1178 This bulletin is intended to present product design solutions and technical information that will help the end user with design applications. Cooper Electronic Technologies reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Electronic Technologies also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
ABC-1/10 价格&库存
很抱歉,暂时无法提供与“ABC-1/10”相匹配的价格&库存,您可以联系我们找货
ABC-1/10
