8414-0113-65
8414-0113-65
    LAIRD(莱尔德)
    ECSFSILTSCFRL
8414-0113-65 数据手册
EMI ESSENTIALS KNITTED CONDUCTIVE GASKETS EXCELLENT VERSATILE SHIELDING PERFORMANCE WITH GREAT VARIETY Wire mesh gaskets are a very versatile and proven style of shielding. Wire mesh gaskets have a great variety of uses and there are several popular types to choose from depending on shielding or environmental requirements. Knitted gaskets can be made from a variety of metal wires, including monel, tin plated-copper clad-steel or aluminum. Cost-effective for low cycling applications with high shielding effectiveness LSBOÐ>Ð?OL>AÐCOBNRBK@VÐO>KDB ÐÐS>FI>?IBÐFKÐ>ÐTFABÐS>OFBQVÐLCÐPFWBPÐ>KAÐPE>MBP ÐQEBÐHKFQÐ@LKPQOR@QFLKÐMOLSFABPÐILKDÐI>PQFKDÐOBPFIFBK@VÐTFQEÐ versatile mounting options. Available with elastomer gasket for moisture and dust sealing. Popular product lines include the ElectroNit™ All Mesh, which is the most economical gasket for low cycling applications and is designed to LCCBOÐQEBÐEFDEBPQÐIBSBIPÐLCÐ>QQBKR>QFLK ÐÐ2IQO>0LCQnÐ(KFQÐLCCBOPÐ@ILPB HKFQÐPQFQ@EÐLCÐQEBÐJBQ>IIFWBAÐKVILKÐMOLSFABPÐ>ÐEFDEIVÐBCCB@QFSBÐ"*&ÐPEFBIA Ð as well as a smooth, soft surface. UltraFlex™ Copper Beryllium (CuBe) Mesh offers superb resiliency for consistent, point-to-point contact OBNRFOFKDÐQEBÐILTBPQÐ@LJMOBPPFLKÐCLO@BPÐ>JLKDÐ>IIÐLQEBOÐPEFBIAFKDÐJ>QBOF>IPÐ>KAÐ@LKÄDRO>QFLKP Elastomer Core Mesh is an optimum solution for combining excellent shielding performance with a high degree of elasticity. Electro-Con oriented wire provides EMI protection and seals against moisture or rain on cast or machined surfaces. Laird maintains a sophisticated global manufacturing network and this, coupled with state-of-the-art design technology, ensures market leading products ideal for your application. Clips, Washers, Tape, etc Electronit All Mesh EMI Gasketing Useful in applications where the need for EMI protection is required. EMI gasketing that has been designed to offer the highest possible levels of attenuation. Elastomer Core Mesh Gasketing Ultraflex Electronit Beryllium Copper Knitted Wire Shielding Elastomer core that offers low compression requirements and low compression set. Optimum mechanical properties of beryllium copper with shielding effectiveness as much as 20 dB higher than conventional materials. 65 www.lairdtech.com EMI ESSENTIALS KNITTED CONDUCTIVE GASKETS VISUAL PART REFERENCE GUIDE UltraFlex ElectroNit BeCu Knitted Wire Shielding Hollow Core Round UltraFlex “D“ Shape Hollow Core Double Round Hollow Core Round with Single Fin ElectroNit All Mesh EMI Gasketing All Mesh Single Round with Fin Strip All Mesh Double Round with Fin Strip All Mesh Rectangular Strip All Mesh Round Strip Enviro-Seal Strip with Pressure-Sensitive Adhesive Double Shield Enviro-Seal Strip with PressureSensitive Adhesive ElectroNit Elastomer Core EMI Gasketing Rectangular with Sponge Elastomer Round with Sponge Elastomer Electronit supersoft Round with Silicone ElastomerTubing ElectroGround EMI Washers 66 www.lairdtech.com Single Fin with Sponge Elastomer Single Fin with Silicone Elastomer Tubing ElectroMesh Tape Double Fin with Sponge Elastomer Double Fin with Silicone Elastomer Tubing UltraSoft Knit EMI ESSENTIALS KNITTED CONDUCTIVE GASKETS PART NUMBER CROSS REFERENCE When ordering, please call our sales department to confirm availability and lead times. KNITTED CONDUCTIVE EMI GASKETS PART NO. PRODUCT 8101-01XX-40,41,47,48,49 ULTRAFLEX ELECTRONIT HOLLOW CORE ROUND 8102-02XX-40,41,47,48,49 ULTRAFLEX D ELECTRONIT WITH PSA 8103-01XX-40,41,47,48,49 ULTRAFLEX ELECTRONIT HOLLOW CORE ROUND WITH SINGLE FIN 8104-01XX-40,41,47,48,49 ULTRAFLEX ELECTRONIT HOLLOW CORE DOUBLE ROUND 8300-XXXX-40,42,43,44,46 ELECTROMESH TAPE 8401-01XX-XX ELECTRONIT ALL MESH RECTANGULAR STRIP 8402-01XX-XX ELECTRONIT ALL MESH ROUND STRIP 8403-01XX-50,52,54,55,60,61 ELECTRONIT SINGLE FIN WITH SPONGE ELASTOMER 8403-01XX-XX ELECTRONIT ALL MESH SINGLE ROUND WITH FIN STRIP 8404-01XX-XX ELECTRONIT ALL MESH DOUBLE ROUND WITH FIN STRIP 8405-01XX-50,52,54,55,60,61 ELECTRONIT ENVIRO-SEAL DOUBLE SHIELD STRIPS WITH PSA 8406-01XX-50,52,54,55,60,61 ELECTRONIT ENVIRO-SEAL STRIPS WITH PSA 8409-01XX-50,52,54,55,60,61 ELECTRONIT RECTANGULAR WITH SPONGE ELASTOMER 8410-01XX-50,52,54,55,60,61 ELECTRONIT ROUND WITH SPONGE ELASTOMER 8412-01XX-50,52,54,55,60,61 ELECTRONIT DOUBLE FIN WITH SPONGE ELASTOMER 8413-01XX-56,64,65 ELECTRONIT ROUND WITH SILICONE ELASTOMER TUBING 8414-01XX-56,64,65 ELECTRONIT SINGLE FIN WITH SILICONE ELASTOMER TUBING 8415-01XX-56,64,65 ELECTRONIT DOUBLE FIN WITH SILICONE ELASTOMER TUBING 843X-2XXX-X ELECTRONIT SUPERSOFT 8417-3XXX-62 ULTRASOFT KNIT GASKETS 89XX-01XX-40,42,43,44,46 ELECTROGROUND EMI WASHERS PAGE NO. 67 www.lairdtech.com
8414-0113-65
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换,具有低导通电阻和快速响应时间。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm。
8414-0113-65 价格&库存
很抱歉,暂时无法提供与“8414-0113-65”相匹配的价格&库存,您可以联系我们找货
