825B-2-3/8
825B-2-3/8
    GREENLEECOMMUNICATIONS(格林利)
    HOLESAW VARIABLE PITCH
825B-2-3/8 数据手册
HOLESAW,VARIABLE PITCH (2 3/8) STD PK 20 Bi-Metal Hole Saws Cat No: 825B-2-3/8 UPC No: 783310380344 Description • • • • • • Cut through steel, tin, aluminum, fiberglass, wood and plastic Deep 1-5/8 IN (41.3 mm) cutting depth allows for cuttingthrough 2 IN x 4 IN wood studs Extra-tough bi-metal bladewe use the highest grade of tool steel to outlast competitor's blades. That beats premature saw replacement and saves you money Steam oxide finish no paint to gum up and slow cutting. The saw runs cooler for longerlife and better performance Extra-thick backplate minimizes vibration for smoother, easier, less tiring cutting Made in USA Specifications • • • • • • • • • • Cutting Size : 1-5/8 IN D Chain : 4 Hole Diameter : 2-3/8 IN Material : Bi-Metal Material Master Number : 50380346 Package : 20/Standard Pack Pipe Tap Size : 2.000 IN Type : Variable Pitch Use With Quick Change Arbor No. : 2801 Use With Standard Arbor No. : 37156
825B-2-3/8 价格&库存
很抱歉,暂时无法提供与“825B-2-3/8”相匹配的价格&库存,您可以联系我们找货
