125Q
125Q
    GREENLEECOMMUNICATIONS(格林利)
125Q 数据手册
GRIP,QUICK CHANGE 3/8 X 1/4 (POP) Quick Change Grip for PullingSingle Wire with 3/8 IN to 1/2 IN (9.500 MM to 12.700 MM). Cat No: 125Q UPC No: 783310127918 Description • • • • Flexible shaft allows easy access to difficult and tight areas Convenient 1/4 IN quick connect receiver accepts most standard quick change accessories Multiple extensions can beeasily joined to create the perfect length for any job Capacity: Any 1/4 IN quickchange accessory 3/4 IN diameter and under Specifications • • • • • Application : For Pulling Wire, Cable Or Fish Tape Through Walls Capacity : 100.000 LB Pulling Force Size : 1/4 IN X 3/8 IN Diameter Type : Quick Change Weight : 0.040 LB
很抱歉,暂时无法提供与“125Q”相匹配的价格&库存,您可以联系我们找货
