TL-30PK4
TL-30PK4
    EATON(伊顿)
    TL-30PK4
TL-30PK4 数据手册
Effective May 2016 Supersedes December 1998 Technical Data 1035 BUSSMANN SERIES Edison base plug fuses – time-delay, 125 volts, 15-30 amps Recommended fuse holders Catalog numbers SOU SRU SSU SOW SRW SSW SOX Catalog symbol: • TL - (amps) • BP/TL - (amps) • TL - (amps)RK4 SRX Bussmann series time-delay, loaded link Edison base plug fuse. ® 2 3/4” handy 4” octagon Type box 4” square Single gang SSN Quantity Weight Amp ratings Per box Per card Per box Per 5 cards 15 to 30 A 4 3 0.24 1.04 Features: Specifications: Ratings • Volts — 125 Vac or less • Amps — 15 to 30 A • Interrupting rating — 10 kA RMS Sym Agency Information • UL® Listed, Std. 248-11, Guide JEFV, File E12112 • CE Catalog numbers (amps) TL - 20 2 1/4” handy Catalog numbers SOY SRY SSY SSY-RL STY SCY SOY-B Package quantity and weight Description: TL - 15 Type box TL - 25 TL - 30 • Medium duty time-delay plug fuse • Will withstand typical motor starting surges • Use in residential or light-duty circuits that contain electric motors • Edison base size • These fuses thread into fuse receptacles or box cover units for supplemental protection Technical Data 1035 Edison base plug fuses time-delay, 125 volts, 15–30 amps Effective May 2016 15 20 35 30 Time-current curve – average melt 100 Amp rating Time in seconds 10 1 2000 1000 100 10 0.01 4 0.1 Current in amps The only controlled copy of this Data Sheet is the electronic read-only version located on the Eaton Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2016 Eaton All Rights Reserved Printed in USA Publication No. 1035 – SB98107 May 2016 For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Follow us on social media to get the Eaton trademarks without prior written latest product and support information. consent of Eaton. UL is a registered trademark of the Underwriters Laboratories, Inc.
TL-30PK4 价格&库存
很抱歉,暂时无法提供与“TL-30PK4”相匹配的价格&库存,您可以联系我们找货
