S-3-2/10
S-3-2/10
    EATON(伊顿)
    FUSTATDUALELEMENTPLUGTYPES
S-3-2/10 数据手册
Technical Data 1032 Effective May 2016 Supersedes August 2002 BUSSMANN SERIES Rejection base plug fuses – dual-element, time-delay 125 volt, up to 30 amps Catalog numbers (amps) Catalog symbol: • • S - (amps) BP/S - (amps) Description: Bussmann® series dual-element, time-delay rejection base plug fuse. Specifications: Ratings • Volts — 125 Vac or less • Amps — 1/4 to 30 A • Interrupting rating — 10 kA RMS Sym S - 1/4 S-2 S - 6-1/4 S - 3/10 S - 2-1/4 S-7 S - 4/10 S - 2-1/2 S-8 S - 1/2 S - 2-8/10 S-9 S - 6/10 S-3 S - 10 S - 8/10 S - 3-2/10 S - 12 S-1 S - 3-1/2 S - 14 S - 1-1/8 S-4 S - 15 S - 1-1/4 S - 4-1/2 S - 20 S - 1-4/10 S-5 S - 25 S - 1-6/10 S - 5-6/10 S - 30 S - 1-8/10 S-6 — Package quantity and weight Quantity Weight Amp ratings Per box Per card Per box Per 5 cards 1/4 to 14 A 4 1 0.24 0.43 15 to 30 A 4 2 0.24 0.68 Agency Information • UL® Listed (up to 6-1/4 A), Std. 248-11, Guide JFHR, File E56412, (7 to 30 A) Guide JEFV, File E12112 • CSA® Certified, Class 1423-01, File 53787 • CE Edison base adaptors Adaptor Accepts fuses Adaptor Accepts fuses SA-1 S-1 or smaller SA-5 S-5 to S-3-1/2 SA-1-1/4 S-1-1/4 or smaller SA-6-1/4 S-6-1/4 to S-3-1/2 SA-1-6/10 S-1-6/10 or smaller SA-8 S-8 to S-7 SA-2 S-2 or S-1-8/10 SA-10 S-10 to S-7 SA-2-1/2 S-2-1/2 to S-1-8/10 SA-15 S-15 to S-7 SA-3-2/10 S-3-2/10 to S-1-8/10 SA-20 S-20 SA-4 S-4 to S-3-1/2 SA-30 S-30 to S-20 Rejection base plug fuses dual-element, time-delay 125 volt, up to 30 amp Technical Data 1032 Effective May 2016 Heavy duty, dual-element, time-delay rejection base fuse • Use to protect critical motor circuits or motors that cycle on/ off frequently • Features non-interchangeable body • An industrial/commerical grade product with dual-element construction • These fuses thread into SA adaptors • Industrial strength, featuring exclusive dual-element construction • This spring loaded design provides superior short circuit and overload protection • More time-delay than the medium duty Type SL fuses in order to better protect industrial motors and critical residential circuits Amp rating 15 20 30 • Time-current curve – average melt 100 10 Time in seconds Features: 1 2000 1000 100 10 0.01 4 0.1 Current in amps The only controlled copy of this Data Sheet is the electronic read-only version located on the Eaton Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2016 Eaton All Rights Reserved Printed in USA Publication No. 1032 – SB02374 May 2016 For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
S-3-2/10
1. 物料型号:文档列出了多种型号的保险丝,包括S-1/4至S-30,以及BP/S系列。
2. 器件简介:Bussmann®系列保险丝是双金属延时拒基座式保险丝,适用于125伏交流电或更低电压,电流范围从1/4到30安培。
3. 引脚分配:文档中没有明确提到引脚分配,但提到了这些保险丝可以旋入SA适配器。
4. 参数特性:保险丝的额定电压为125伏交流电或更低,电流范围从1/4到30安培,中断额定值为10kA RMS对称。
5. 功能详解:这些保险丝具有重型双金属延时结构,用于保护关键电机电路或频繁开关的电机。它们是非可互换的,具有工业/商业级产品特性。
6. 应用信息:适用于工业强度,具有独特的双金属结构,提供优越的短路和过载保护。
7. 封装信息:文档提供了包装数量和重量信息,例如1/4至14A的保险丝每盒4个,每张卡片1个,每盒重量0.24,每5张卡片的重量为0.43。
S-3-2/10 价格&库存
很抱歉,暂时无法提供与“S-3-2/10”相匹配的价格&库存,您可以联系我们找货
S-3-2/10
  • 4+481.792924+60.41776
