38524
38524
    GREENLEECOMMUNICATIONS(格林利)
    ARBOR-.312 HEX BLST PKGD
38524 数据手册
ARBOR-.312 HEX BLST PKGD Arbors with Replacement High-Speed Steel Pilot Drill Bits Cat No: 38524 UPC No: 783310385240 Description • • • • • The best arbor in the industry ensures a solid connectionwithout any gaps or wobbling Arbors include replaceable, high-speed steel pilot drill Pilot drills have unique split-point tip design Use with Greenlee bimetal hole saws, recessed light holesaws and carbide-grit hole saws (carbide-tipped pilot drillsold separately) Can be used with Greenlee #901 or #904 bit extensions Specifications • • • • • • • Application : Use With Greenlee Bimetal Hole Saws, Recessed Light Hole Saws And Carbide-Grit Hole Saws (Carbide-Tipped Pilot Drill Sold Separately), Can Be Used With Greenlee NO 901 Or 904 Bit Extensions, 9/16 IN - 1-3/16 IN (14.300 - 30.200 MM) Hole Saws Material : High Speed Steel Pilot Drill Bit Minimum Chuck Size : 3/8 IN (9.500 MM) Package : Point of Purchase Pack Shank Diameter : 5/16 IN (7.900 MM) Type : Hex Shank Weight : 0.200 LB (91.000 GM)
38524 价格&库存
很抱歉,暂时无法提供与“38524”相匹配的价格&库存,您可以联系我们找货
