HANDSAW, PACKAGED (POP)
Retractable Saw Set
Cat No:
311
UPC No:
783310131106
Description
6 IN blade retracts into the handle for convenience and safety
Quickly change blade for added versatility
Accepts most 6 IN (or shorter) standard reciprocating saw blades
Ergonomically designed handle allows force to be appliedboth on the push and pull stroke
Built-in blade storage area can hold 2 additional blades
Adjustable blade can be used at any length or the 3 hardstops can be used for aggressive sawing
Jab blade and a bi-metal blade included.U.S. Patent #D527,602.
Note: This is not an insulated tool
Specifications
Blade Length : 6.000 IN
Capacity :
ƕ For Jab Blade: Drywall, Ceiling Tile, Wood
ƕ For Bimetal Blade: Conduit, Metal, PVC, Plastics
Height : 1-3/4 IN (4.300 CM)
Overall Length : 8-3/8 IN (21.300 CM) (33.000 CM Blade Extended)
Type : Retractable
Weight : 0.350 LB (1.600 KG)
Width : 1-1/8 IN (2.800 CM)
很抱歉,暂时无法提供与“311”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+205.392315+26.60549
