825-3-1/4
825-3-1/4
    GREENLEECOMMUNICATIONS(格林利)
    HOLESAW VARIABLE PITCH
825-3-1/4 数据手册
HOLESAW,VARIABLE PITCH (3 1/4") Bi-Metal Hole Saws Cat No: 825-3-1/4 UPC No: 783310191698 Description • • • • • • Cut through steel, tin, aluminum, fiberglass, wood and plastic Deep 1-5/8 IN (41.3 mm) cutting depth allows for cuttingthrough 2 IN x 4 IN wood studs Extra-tough bi-metal blade- we use the highest grade oftool steel to outlast competitor's blades. That beats premature saw replacement and savesyou money Steam oxide finish - no paint to gum up and slow cutting. The saw runs cooler for longer life and better performance Extra-thick backplate minimizes vibration for smoother, easier, less tiring cutting Made in USA Specifications • • • • • • Cutting Size : 1-5/8 IN Hole Diameter : 3-1/4 IN Material : Bi-Metal Type : Variable Pitch Use With Quick Change Arbor No. : 2801 Use With Standard Arbor No. : 37156
825-3-1/4 价格&库存
很抱歉,暂时无法提供与“825-3-1/4”相匹配的价格&库存,您可以联系我们找货
