SFD27
SFD27
    EATON(伊顿)
    SICHERUNGSUNTERTEIL D1 E27 1POL
SFD27 数据手册
Technical Data 4124 Effective October 2017 Supersedes July 2017 BUSSMANN SERIES D and D0 fuse links and bases Product description Eaton’s Bussmann® series Type D and D0 fuse links are specifically designed for the protection of general industrial applications such as power distribution and cable protection. Both types D and D0 are available in three operating characteristics: Time-delay, Fast-acting and Ultra-rapid versions that fit into screw cap fuse link carriers for mounting in 1- or 3-pole DIN-Rail or screw fixing. Features and benefits: • Characteristics to suit the protection needs of inductive and resistive loads • Fast trouble shooting with easily visible fuse operated pin indicator • Historically reliable range • Wide range of fuse bases and accessories available for many applications • Compliant to IEC 60269 and DIN 49515 Technical Data 4124 D and D0 fuse links and bases Effective October 2017 Catalogue symbol - Type D fuse links Fuse Link Size Time-Delay Fast-acting Ultra-rapid DI DII DIII DIV DV (amp)D16 (amp)D27 (amp)D33 (amp)D125 (amp)D200 (amp)D16Q (amp)D27Q (amp)D33Q (amp)D125Q (amp)D200Q (amp)D16R (amp)D27R (amp)D33R (amp)D125R (amp)D200R Fuse size • DI • DII • DIII • DIV • DV To be used with fuse base • E16 (DI) • E27 (DII) • E33 (DIII) • R1 ¼” (DIV) • R2 (DV) Technical data • Volts: 500 V a.c. • Amps: 2 to 200 A • Breaking capacity: 50 kA Class of operation • Time-delay • Fast-acting • Ultra-rapid Standards/Approvals • IEC 60269 and DIN 49515 Fuse bases and accessories (ordered separately) • CD27 and CD33 Screw cap fuse link carriers • GD27 and GD33 Screw cap gauge pieces • SFD (1-pole) and TFD (3-pole) Fuse base screw fixing • SFRD (1-pole) and TFRD (3-pole) Fuse base DIN-Rail mount Weight • D16: 12 - 16 grams • D27: 27 - 30 grams • D33: 48 - 52 grams • D125: 105 - 109 grams • D200: 215 grams 2 EATON www.eaton.com Table 1. Technical data Current (Amps) I2t (Amp2 seconds) Nominal watts loss 2 4 6 10 16 20 25 35 50 63 80 100 125 160 200 33 52 100 160 460 1100 2000 4700 7800 12300 19000 29000 N/A N/A N/A 1.5 1.6 1.8 1.4 2.1 2.2 3 4.1 5 6.9 N/A N/A N/A N/A N/A Technical Data 4124 D and D0 fuse links and bases Effective October 2017 Table 2. Type D Catalogue numbers time delay and fast acting Fuse link Operating characteristics Gauge ring colour Fuse link size To fit fuse base Current (Amps) Voltage (V a.c.) B dimensions Pack quantity 2D16 Time-delay Pink DI E16 2 500 6 10 4D16 6D16 10D16 16D16 20D16 25D16 2D27 4D27 6D27 10D27 16D27 20D27 25D27 32D33 35D33 40D33 50D33 63D33 80D125 100D125 125D200 160D200 200D200 2D16Q 4D16Q 6D16Q 10D16Q 16D16Q 20D16Q 25D16Q 2D27Q 4D27Q 6D27Q 10D27Q 16D27Q 20D27Q 25D27Q 35D33Q 50D33Q 63D33Q Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Time-delay Fast acting Fast acting Fast acting Fast acting Fast acting Fast acting Fast acting Fast acting Fast acting Fast acting Fast acting Fast acting Fast acting Fast acting Fast acting Fast acting Fast acting Brown Green Red Grey Blue Yellow Pink Brown Green Red Grey Blue Yellow Black Black Black White Copper Silver Red Yellow Copper Blue Pink Brown Green Red Grey Blue Yellow Pink Brown Green Red Grey Blue Yellow Black White Copper DI DI DI DI DI DI DII DII DII DII DII DII DII DIII DIII DIII DIII DIII DIV DIV DV DV DV DI DI DI DI DI DI DI DII DII DII DII DII DII DII DIII DIII DIII E16 E16 E16 E16 E16 E16 E27 E27 E27 E27 E27 E27 E27 E33 E33 E33 E33 E33 R1 ¼” R1 ¼” R2 R2 R2 E16 E16 E16 E16 E16 E16 E16 E27 E27 E27 E27 E27 E27 E27 E33 E33 E33 4 6 10 16 20 25 2 4 6 10 16 20 25 32 35 40 50 63 80 100 125 160 200 2 4 6 10 16 20 25 2 4 6 10 16 20 25 35 50 63 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 6 6 8 10 12 14 6 6 6 8 10 12 14 16 16 16 18 20 5 7 5 7 9 6 6 6 8 10 12 14 6 6 6 8 10 12 14 16 18 20 10 10 10 10 10 10 25 25 25 25 25 25 25 25 25 25 25 25 3 3 10 10 10 10 10 10 10 10 10 10 25 25 25 25 25 25 25 25 25 25 80D125Q 100D125Q 125D200Q 160D200Q 200D200Q Fast acting Fast acting Fast acting Fast acting Fast acting Silver Red Yellow Copper Blue DIV DIV DV DV DV R1 ¼” R1 ¼” R2 R2 R2 80 100 125 160 200 500 500 500 500 500 5 7 5 7 9 10 10 10 10 10 EATON www.eaton.com 3 Technical Data 4124 D and D0 fuse links and bases Effective October 2017 Table 3. Type D Catalogue numbers ultra rapid Fuse link Operating characteristics Gauge ring colour Fuse link size To fit fuse base Current (Amps) Voltage (V a.c.) B dimensions Pack quantity 2D16R 4D16R 6D16R 10D16R 16D16R 20D16R 25D16R 2D27R 4D27R 6D27R 10D27R 16D27R 20D27R 25D27R 30D27R 35D33R 50D33R 63D33R 80D125R 100D125R 125D200R 160D200R 200D200R Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Pink Brown Green Red Grey Blue Yellow Pink Brown Green Red Grey Blue Yellow Black Black White Copper Silver Red Yellow Copper Blue DI DI DI DI DI DI DI DII DII DII DII DII DII DII DII DIII DIII DIII DIV DIV DV DV DV E16 E16 E16 E16 E16 E16 E16 E27 E27 E27 E27 E27 E27 E27 E27 E33 E33 E33 R1 ¼” R1 ¼” R2 R2 R2 2 4 6 10 16 20 25 2 4 6 10 16 20 25 30 35 50 63 80 100 125 160 200 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 6 6 6 8 10 12 14 6 6 6 8 10 12 14 14 16 18 20 5 7 5 7 9 20 20 20 20 20 20 20 25 25 25 25 25 25 25 25 25 25 25 3 3 10 10 10 Dimensions - mm  DI 4  DII EATON www.eaton.com  DIII  DIV  DV Technical Data 4124 D and D0 fuse links and bases Effective October 2017 Time-current curve - Type D Fuse links 2 10 4 6 4 2A 4A 6A 13A 32A 40A 10A 16A 20A 25A 35A 50A 63A 80A 100A 2 10 3 6 4 2 Time in seconds (S) 10 2 6 4 2 10 1 6 4 2 10 0 6 4 2 -1 10 6 4 2 -2 10 6 4 4 6 10 1 2 4 10 6 2 4 2 10 6 3 2 Current in Amps (A) Cut-off characteristics - Type D Fuse links 2 100 80 63 50 4 35 3 25 20 16 1 10 2 2I K 2I K 4 10 6 4 2 4 2 6 4 In/A Maximum value of current (A) 6 3 10 2 2 10 6 4 2 1 10 1 10 2 4 6 10 2 2 4 6 10 3 Prospective current (A) 5 EATON www.eaton.com 2 4 6 10 4 2 4 Technical Data 4124 D and D0 fuse links and bases Effective October 2017 Accessories for type D Fuse links Table 4. Screw cap fuse links carriers Screws into fuse base. Catalogue number Fuse link size To fit fuse base type Current (Amps) Pack qty CD27 CD33 DII DIII E27 E33 25 63 50 30 Dimensions - mm CD27 Rated current (Amps) CD27 CD33 A E27 E33 B 44 44 C 12 12 D 34 43 Fuse carrier/cap Table 5. Screw cap gauge pieces Fuse rating rejection insert to prevent incorrect fuse rating from being installed. Catalogue number Colour Current (Amps) Fuse link size To fit fuse base type Pack qty 2GD27 4GD27 6GD27 10GD27 16GD27 20GD27 25GD27 35GD33 50GD33 63GD33 Pink Brown Green Red Grey Blue Yellow Black White Copper 2 4 6 10 16 20 25 35 50 63 DII DII DII DII DII DII DII DIII DIII DIII E27 E27 E27 E27 E27 E27 E27 E33 E33 E33 25 25 25 25 25 25 25 25 25 25 Dimensions - mm Gauge piece 2GD27 20GD27 4GD27 6GD27 25GD27 35GD33 10GD27 50GD33 Rated current (Amps) 2GD27 4GD27 6GD27 10GD27 16GD27 20GD27 25GD27 35GD33 50GD33 63GD33 A 3/16” 3/16” 3/16” 3/16” 3/16” 3/16” 3/16” 3/16” 3/16” 3/16” B 6.5 6.5 6.5 8.5 10.5 12.5 14.5 16.5 18.5 20.5 C 17 17 17 17 17 17 17 17 17 17 D 24 24 24 24 24 24 24 30 30 30 16GD27 63GD33 EATON www.eaton.com 6 Technical Data 4124 D and D0 fuse links and bases Effective October 2017 Table 6. Fuse base screw fixing Panel mount receptacle to hold screw cap fuse link carrier and fuse link. Catalogue number Number of poles Fuse link size To fit fuse base type Current (Amps) Pack qty TFD27 TFD33 3-pole 3-pole DII DIII E27 E33 25 63 4 6 TFD27 Dimensions - mm Rated current (Amps) A TFD27 41 TFD33 43 B C 121 44 148 44 D 47 47 E 60 56 F 30 32 G 4.3 4.3 H 50 62 TFD Table 7. Fuse base DIN-Rail mount DIN-Rail mount receptacle to hold screw cap fuse link carrier and fuse link. Catalogue number Number of poles Fuse link size To fit fuse base type Current (Amps) Pack qty SFRD27 TFRD27 SFRD33 TFRD33 1-pole 3-pole 1-pole 3-pole DII DII DIII DIII E27 E27 E33 E33 25 25 63 63 15 4 15 6 TFRD27 SFRD33 Dimensions - mm Rated current (Amps) A SFRD27 41 SFRD33 43 B 39 47 Rated current (Amps) A TFRD27 41 TFRD33 43 B C 121 44 148 44 C 44 44 D 47 47 E 60 56 F 62 79 SFRD Dimensions - mm TFRD 7 EATON www.eaton.com D 47 47 E 60 56 F 30 32 G 4.3 4.3 H 50 62 Technical Data 4124 D and D0 fuse links and bases Effective October 2017 Fitting example + + + CD27 10GD27 10D27 TFD27 Screw cap fuse Screw cap gauge piece Fuse link Fuse base link carrier panel mount EATON www.eaton.com 8 Technical Data 4124 D and D0 fuse links and bases Effective October 2017 Catalogue symbol - Type D0 fuse links Fuse link size Time-delay Ultra-rapid D01 D02 D03 (amp)NZ01 (amp)NZ02 (amp)NZ03 (amp)NZ01R (amp)NZ02R N/A Table 8. Technical data Fuse size • D01 • D02 • D03 Current (Amps) I2t (Amp2 seconds) Nominal watts loss 2 4 6 10 16 20 25 35 50 63 33 52 100 160 460 1100 2000 4700 7800 12300 0.8 1.1 1.2 1.1 1.7 1.7 2.3 2.8 3.8 5 To be used with fuse base • E14 (D01) • E18 (D02) • M30 x 2 (D03) Fuse bases and accessories (ordered separately) Technical data • Volts: 400 V a.c. • Amps: 2 to 100 A • Breaking capacity: 50 kA Operating class • CN01, CN02 and CN03 screw cap fuse link carriers • GN01 and GN02 screw cap gauge pieces • FN_C, FRNC-SA, FRN-SB, FRN-SD, FRN-SE single pole fuse base screw fixing • TFN_C, TFRNC-SA, TFRN-SB, TFRN-SD, TFRN-SE triple pole fuse base screw fixing • FRN_C, FRNC-A, FRN-B, FRN-D, FRN-E single pole fuse base DIN-Rail mounting • TFRN_C, TFRNC-A, TFRN-B, TFRN-D, TFRN-E triple pole fuse base DIN-Rail mounting • Time-delay • PPD01 and PPD02 Plastic base • Ultra-rapid • D0-GPK gauge piece key • D0-SFH special holder Standards/Approvals • IEC 60269 and DIN 49515 See catalogue numbers table for dimension A. Packaging • Dimensions - mm 10 per carton Weight • NZ01: 6 grams • NZ02: 11 - 15 grams • NZ03: 35 grams Use with fuse base E14 9 EATON www.eaton.com Use with fuse base E18 Use with fuse base M30 x 2 Technical Data 4124 D and D0 fuse links and bases Effective October 2017 Table 9. Type D0 fuse link catalogue numbers Catalogue numbers Operating characteristics Gauge ring colour Fuse link size To fit fuse base Current (Amps) Voltage (V a.c.) A dimensions Pack qty 2NZ01 4NZ01 6NZ01 10NZ01 16NZ01 20NZ02 25NZ02 35NZ02 50NZ02 63NZ02 80NZ03 100NZ03 2NZ01R 4NZ01R 6NZ01R 10NZ01R 16NZ01R 20NZ02R 25NZ02R 35NZ02R 50NZ02R 63NZ02R Time delay Time delay Time delay Time delay Time delay Time delay Time delay Time delay Time delay Time delay Time delay Time delay Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Ultra rapid Pink Brown Green Red Grey Blue Yellow Black White Copper Silver Red Pink Brown Green Red Grey Blue Yellow Black White Copper D01 D01 D01 D01 D01 D02 D02 D02 D02 D02 D03 D03 D01 D01 D01 D01 D01 D02 D02 D02 D02 D02 E14 E14 E14 E14 E14 E18 E18 E18 E18 E18 M30 x 2 M30 x 2 E14 E14 E14 E14 E14 E18 E18 E18 E18 E18 2 4 6 10 16 20 25 35 50 63 80 100 2 4 6 10 16 20 25 35 50 63 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 7.3 7.3 7.3 8.5 9.7 10.9 12.1 13.3 14.5 15.9 21.4 21.4 7.3 7.3 7.3 8.5 9.7 10.9 12.1 13.3 14.5 15.9 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 EATON www.eaton.com 10 Technical Data 4124 D and D0 fuse links and bases Effective October 2017 Time in seconds (S) Time-current curve - Type D0 fuse links - Time-delay Current in Amps (A) Maximum value of current (A) Cut-off characteristics - Type D0 Fuse link - Time-delay and Ultra-rapid Prospective current (A) EATON www.eaton.com 11 Technical Data 4124 D and D0 fuse links and bases Effective October 2017 Accessories for type D0 Fuse links Table 10. Fuse cap fuse link carriers Screws into fuse base. Catalogue number Fuse link size Pack qty CN01 CN02 CN03 D01 D02 D03 20 20 20 CN01 Dimensions - mm Fuse carrier/cap Table 11. Screw cap gauge pieces Fuse rating rejection insert to prevent incorrect fuse rating from being installed. Dimensions Catalogue number 2GN01 4GN01 6GN01 10GN01 2GN02* 4GN02* 6GN02* 10GN02* 16GN02* 20GN02 25GN02 35GN02 50GN02 Colour Current (Amps) Fuse link size To fit fuse base type Pack qty A B Pink Brown Green Red Pink Brown Green Red Grey Blue Yellow Black White 2 4 6 10 2 4 6 10 16 20 25 35 50 D01 D01 D01 D01 D02 D02 D02 D02 D02 D02 D02 D02 D02 E14 E14 E14 E14 E18 E18 E18 E18 E18 E18 E18 E18 E18 50 50 50 50 50 50 50 50 50 50 50 50 50 7.9 7.9 7.9 9.1 7.9 7.9 7.9 9.1 10.3 11.5 12.7 13.9 15.1 12 12 12 12 16.6 16.6 16.6 16.6 16.6 16.6 16.6 16.6 16.6 Dimensions - mm * For using fuse links D01 and fuse bases D02 2GN01 20GN02 12 4GN01 25GN02 EATON www.eaton.com 6GN01 35GN02 10GN01 50GN02 16GN02 Technical Data 4124 D and D0 fuse links and bases Effective October 2017 Table 12. Single pole fuse base Panel mount receptacle to hold screw cap fuse link carrier and fuse link. Connections Catalogue number Current (Amps) Screw FRN01C FN01C FRN02C FN02C FRN02C-A FRN02C-SA FRN01-B FRN01-SB FRN02-D FRN02-SD FRN02-E FRN02-SE 16 16 63 63 63 63 16 16 63 63 63 63 E14 E14 E18 E18 E18 E18 E14 E14 E18 E18 E18 E18 With protection cover Without protection cover x x x x x x DIN-Rail mounting Screw fixing x x x x x x x x x x x x x x x x x x Outlet Supply Crosssection of connecting lead (mm2) M4 M4 2 x M5 2 x M5 2 x M5 2 x M5 M4 M4 2 x M5 2 x M5 2 x M5 2 x M5 M4 M4 2 x M5 2 x M5 M6 M6 M4 M4 2 x M5 2 x M5 M6 M6 1.5-4 1.5-4 2.5-25 2.5-25 2.5-25 2.5-25 1.5-4 1.5-4 2.5-25 2.5-25 2.5-25 2.5-25 Dim (A) mm Pack qty 53 53 57 57 57 57 53 53 57 57 57 57 15 15 15 15 5 15 15 15 5 15 15 15 Dimensions - mm FN01C FRN01C Table 13. Three pole fuse base Panel mount receptacle to hold screw cap fuse link carrier and fuse link. Connections Catalogue number Current (Amps) Screw TFRN01C TFN01C TFRN02C TFN02C TFRN02C-A TFRN02C-SA TFRN01-B TFRN01-SB TFRN02-D TFRN02-SD TFRN02-E TFRN02-SE 16 16 63 63 63 63 16 16 63 63 63 63 E14 E14 E18 E18 E18 E18 E14 E14 E18 E18 E18 E18 With protection cover Without protection cover x x x x x x DIN-Rail mounting Screw fixing x x x x x x x x x x x x x x x x x x Outlet Supply Crosssection of connecting lead (mm2) M4 M4 2 x M5 2 x M5 2 x M5 2 x M5 M4 M4 2 x M5 2 x M5 2 x M5 2 x M5 M4 M4 2 x M5 2 x M5 M6 M6 M4 M4 2 x M5 2 x M5 M6 M6 1.5-4 1.5-4 2.5-25 2.5-25 2.5-25 2.5-25 1.5-4 1.5-4 2.5-25 2.5-25 2.5-25 2.5-25 Dim (A) (mm) Pack qty 53 53 57 57 57 57 53 53 57 57 57 57 5 5 5 5 5 5 5 5 5 5 5 5 Dimensions - mm TFRN02C EATON www.eaton.com 13 Technical Data 4124 D and D0 fuse links and bases Effective October 2017 Accessories for type D0 Fuse links Table 14. Plastic base PDD01 and PDD02 Type Catalogue number To fit fuse link Number of poles Rated current (A) Dim B (mm) Pack qty PPD01-1 PPD01-3 PPD02-1 PPD02-3 PDD01-1 PDD01-3 PDD02-1 PDD02-3 D01 D01 D02 D02 1 3 1 3 16 16 63 63 26.8 80.4 26.8 80.4 1 3 15 5 Dimensions - mm Table 15. Gauge piece key Catalogue number Pack MOQ qty D0-GPK 20 20 Table 16. Special holder Catalogue number Pack qty D0-SFH 25 Fitting example + CN01 Fuse cap fuse link carrier + + + 16GN02 16NZ01 FRN02C Screw cap gauge ring Fuse link DIN-Rail fuse mount Eaton EMEA Headquarters Route de la Longeraie 7 1110 Morges, Switzerland Changes to the products, to the information contained in this document, and to prices are reserved; so are errors and omissions. Only order confirmations and technical documentation by Eaton is binding. Photos and pictures also do not warrant a specific layout or functionality. Their use in whatever form is subject to prior approval by Eaton. The same applies to Trademarks (especially Eaton, Moeller, and Cutler-Hammer). The Terms and Conditions of Eaton apply, as referenced on Eaton Internet pages and Eaton order confirmations. Eaton Electrical Products Limited Melton Road Burton-on-the-Wolds Leicestershire, LE12 5TH United Kingdom © 2017 Eaton All Rights Reserved PDF Only Publication No. 4124 October 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
SFD27 价格&库存
很抱歉,暂时无法提供与“SFD27”相匹配的价格&库存,您可以联系我们找货
