LPN-RK-35SP
LPN-RK-35SP
    EATON(伊顿)
LPN-RK-35SP 数据手册
Low-Peak™ 250V Class RK1 LPN-RK — 250Vac/dc, 70-600A, Dual Element, Time-Delay Fuses Dimensions - in A B Available with easyID™ open fuse indication Description: Ultimate protection Class RK1 dual element, current-limiting, time-delay fuses available with optional open fuse indication. Ratings: Volts — 250Vac/dc Amps — 70-600A IR — 300kA Vac RMS Sym. — 100kA Vdc Agency Information: CE, UL Listed, Guide JDDZ, File E4273 CSA Certified, Class 1422-02, File 53787, Class RK1 per CSA C22.2 No. 248.12 Catalog Numbers (amps) — Non-indicating Fuses* LPN-RK-70SP LPN-RK-150SP LPN-RK-350SP LPN-RK-80SP LPN-RK-175SP LPN-RK-400SP LPN-RK-90SP LPN-RK-200SP LPN-RK-450SP LPN-RK-100SP LPN-RK-225SP LPN-RK-500SP LPN-RK-110SP LPN-RK-250SP LPN-RK-600SP LPN-RK-125SP LPN-RK-300SP Applications: • Feeder and Branch Circuits • Motors • General Purpose Circuits * Open fuse indication available on all part numbers by inserting the suffix “I,” e.g., LPN-RK-90SPI. Requires 75Vac minimum voltage. Amp Rating Carton Qty. 70–100 110–200 225–400 450–600 5 1 1 1 A 5.88 (± 0.062) 7.13 (± 0.062) 8.63 (± 0.094) 10.38 (± 0.094) B 1.10 (± 0.02) 1.61 (± 0.02) 2.36 (± 0.02) 2.88 (± 0.02) Features: • Industry’s only UL Listed and CSA Certified fuse with a 300kA Vac interrupting rating that exceeds requirements for virtually all applications • Fast short-circuit protection provides optimal arc flash protection to reduce hazard to personnel • Easy selective coordination with all Low-Peak fuses using simple 2:1 ampacity ratio • Current-limiting for maximum short-circuit protection • “No damage” Type “2” protection for IEC and NEMA motor starters when properly sized • High in-rush current motor protection • Time-delay that permits 130% FLA sizing for back-up motor protection • Provides protection against single-phase motor damage • Low watt loss power consumption • Electrically isolated end caps for added safety Catalog Symbols: LPN-RK-(amp)SP (non-indicating) LPN-RK-(amp)SPI (indicating) Carton Quantity and Weight Amp Rating 70-100 110-200 225-400 450-600 • Transformers • Solenoids Recommended Fuse Blocks Fuse Amps 70-100 110-200 225-400 450-600 1-Pole RM25100-1CR RM25200-1CR RM25400-1CR RM25600-1CR 2-Pole RM25100-2CR RM25200-2CR RM25400-2CR RM25600-2CR 3-Pole RM25100-3CR RM25200-3CR RM25400-3CR RM25600-3CR For additional information on the RM Series of 250 volt fuse blocks, see product brochure # 3192. Fuse Reducers For Class R Fuses Equipment Fuse Clips 200A 400A 600A Desired Fuse (Case) Size 100A 100A 200A 100A 200A 400A Catalog Numbers (Pairs) 250V NO.2621-R NO.2641-R NO.642-R NO.2661-R NO.2662-R NO.2664-R† † Single reducer only (pair not required). For additional information on Class R fuse reducers, see Data Sheet # 1118. 0713 BU-SB13687 Page 1 of 3 Data Sheet # 1004 Low-Peak™ 250V Class RK1 LPN-RK — 250Vac/dc, 70-600A, Dual Element, Time-Delay Fuses Time-Current Curves - Average Melt 600 400 200 100 TIME IN SECONDS 60 AMP RATING CURRENT IN AMPS NOTE: 60 Amp fuse curve is ferrule style and included to show only relative performance. For actual 60 amp time-current curve performance, see Data Sheet 1003. 0713 BU-SB13687 Page 2 of 3 Data Sheet # 1004 Low-Peak™ 250V Class RK1 LPN-RK — 250Vac/dc, 70-600A, Dual Element, Time-Delay Fuses Current-Limitation Curves B 400,000 300,000 AMP RATING 100,000 90,000 80,000 70,000 60,000 50,000 600A 40,000 400A 30,000 200A 20,000 100A 10,000 9,000 8,000 7,000 6,000 5,000 4,000 3,000 A 300,000 80,000 60,000 30,000 40,000 20,000 8,000 10,000 6,000 4,000 2,000 3,000 1,000 1,000 200,000 2,000 100,000 INSTANTANEOUS PEAK LET-THROUGH CURRENT IN AMPERES 200,000 PROSPECTIVE SHORT-CIRCUIT CURRENT - SYMMETRICAL RMS AMPS Current-Limiting Effects Prosp. Let-Through Current S.C.C. (Apparent RMS Symmetrical Vs. Fuse Rating) — 100A 200A 400A 600A 1000 1000 1000 1000 1000 2000 2000 2000 2000 2000 3000 2000 3000 3000 3000 5000 2000 3000 5000 5000 10,000 3000 4000 7000 9000 15,000 3000 5000 8000 11,000 20,000 3000 5000 8000 11,000 25,000 3000 5000 9000 12,000 30,000 4000 6000 9000 12,000 35,000 4000 6000 10,000 13,000 40,000 4000 6000 10,000 13,000 50,000 4000 7000 11,000 14,000 60,000 4000 7000 11,000 16,000 70,000 4000 7000 12,000 16,000 80,000 5000 8000 12,000 16,000 90,000 5000 7000 13,000 17,000 100,000 5000 8000 13,000 17,000 150,000 6000 9000 15,000 19,000 200,000 6000 11,000 16,000 20,000 250,000 7000 11,000 17,000 21,000 300,000 7000 12,000 18,000 22,000 The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 0713 BU-SB13687 Page 3 of 3 Data Sheet # 1004
LPN-RK-35SP 价格&库存
很抱歉,暂时无法提供与“LPN-RK-35SP”相匹配的价格&库存,您可以联系我们找货
