ARBOR-HOLESAW .437 HEX
Arbors with Replacement High-Speed Steel Pilot Drill Bits
Cat No:
38505
UPC No:
783310385059
Description
The best arbor in the industry ensures a solid connectionwithout any gaps or wobbling
Arbors include replaceable, high-speed steel pilot drill
Pilot drills have unique split-point tip design
Use with Greenlee bimetal hole saws, recessed light holesaws and carbide-grit hole saws
(carbide-tipped pilot drillsold separately)
Can be used with Greenlee #901 or #904 bit extensions
Specifications
Application : Use With Greenlee Bimetal Hole Saws, Recessed Light Hole Saws And Carbide-grit
Hole Saws (Carbide-Tipped Pilot Drill Sold Separately), Can Be Used With Greenlee NO 901 Or
904 Bit Extensions, 9/16 IN - 1-3/16 IN (14.300 - 30.200 MM) Hole Saws
Material : High Speed Steel Pilot Drill Bit
Minimum Chuck Size : 1/2 IN (12.700 MM)
Package : Point of Purchase Pack
Shank Diameter : 7/16 IN (11.100 MM)
Type : Hex Shank
Weight : 0.200 LB (91.000 GM)
很抱歉,暂时无法提供与“38504”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+303.338431+39.43302
