Technical Data 720132
Effective September 2015
Supersedes May 2015
BUSSMANN
SERIES
Bussmann series
14 x 51 mm Photovoltaic fuse links
Description
Eaton’s Bussmann series range of 14 x 51 mm
package fuse links is specifically designed for
protecting an isolating photovoltaic strings.
These fuse links are capable of interrupting low
overcurrents associated with faulted PV systems
(reverse current, multi array fault).
Bussmann series
Catalogue symbol
Table 1. Technical data
PV-(amp rating)A14F
14 x 51 mm
Technical data
Rated voltage:
1000 V d.c. (25 and 32 A)
1100 V d.c. (15 and 20 A)
Rated current: 15 to 32 A
Breaking capacity: 10 kA
Class of operation: gPV and UL PV fuse links
PV fuse coordinationw/: Thin film cells and 4”, 5” and 6”
crystalline sillicon cells
Time constant: 1-3 ms
Minimum interrupting rating:
1.5 x In for 15 - 20 A
1.75 x In for 25 - 32 A
Watts loss
Pre-arcing
Total at rated
voltage
08 In
In
1100
14
265
2.1
4
1100
27
568
2.7
5
25
1000
65
943
2.7
5.1
32
1000
120
1740
3.3
6.2
Rated
current
(Amps)
Rated
voltage
(V d.c.)
PV-15A14F
15
PV-20A14F
PV-25A14F
PV-32A14F
Fuse size
Energy integrals I2t (A2s)
Catalogue
number
Standards/Approvals:
IEC 60269-6
UL 2579 (File number E335324)
RoHS compliant
Fuse holders:
CHPV141B
CHPV141BI
Packaging:
MOQ: 10
Packaging: 100% recyclable
Dimensions - mm
2
EATON www.eaton.com
Bussmann series
Time-current curve
10000
32A
1000
25A
20A
15A
Time in Seconds (s)
100
10
1
0.1
0.01
1
10
100
1000
Available current, DC-Time constant 1-3ms (Amps)
Changes to the products, to the information
contained in this document, and to prices
are reserved; so are errors and omissions.
Only order confirmations and technical
documentation by Eaton is binding. Photos
and pictures also do not warrant a specific
layout or functionality. Their use in whatever
form is subject to prior approval by Eaton.
The same applies to Trademarks (especially
Eaton, Moeller, and Cutler-Hammer). The
Terms and Conditions of Eaton apply, as
referenced on Eaton Internet pages and
Eaton order confirmations.
Eaton
EMEA Headquarters
Route de la Longeraie 7
1110 Morges, Switzerland
Eaton.eu
© 2015 Eaton
All Rights Reserved
Publication No. 720132
September 2015
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“PV-15A14F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+158.2281310+20.38520
- 国内价格 香港价格
- 10+750.2986710+96.66416
