PV-25A14F
PV-25A14F
    EATON(伊顿)
    FUSE25AMP1000VDCSOLARFERRUL
PV-25A14F 数据手册
Technical Data 720132 Effective September 2015 Supersedes May 2015 BUSSMANN SERIES Bussmann series 14 x 51 mm Photovoltaic fuse links Description Eaton’s Bussmann series range of 14 x 51 mm package fuse links is specifically designed for protecting an isolating photovoltaic strings. These fuse links are capable of interrupting low overcurrents associated with faulted PV systems (reverse current, multi array fault). Technical Data 720132 Bussmann series 14 x 51 mm Photovoltaic fuse links Effective September 2015 Catalogue symbol • Table 1. Technical data PV-(amp rating)A14F 14 x 51 mm Technical data • Rated voltage: • 1000 V d.c. (25 and 32 A) • 1100 V d.c. (15 and 20 A) • Rated current: 15 to 32 A • Breaking capacity: 10 kA • Class of operation: gPV and UL PV fuse links • PV fuse coordinationw/: Thin film cells and 4”, 5” and 6” crystalline sillicon cells • Time constant: 1-3 ms • Minimum interrupting rating: • 1.5 x In for 15 - 20 A • 1.75 x In for 25 - 32 A Watts loss Pre-arcing Total at rated voltage 08 In In 1100 14 265 2.1 4 1100 27 568 2.7 5 25 1000 65 943 2.7 5.1 32 1000 120 1740 3.3 6.2 Rated current (Amps) Rated voltage (V d.c.) PV-15A14F 15 PV-20A14F 20 PV-25A14F PV-32A14F Fuse size • Energy integrals I2t (A2s) Catalogue number Standards/Approvals: • IEC 60269-6 • UL 2579 (File number E335324) • RoHS compliant Fuse holders: • CHPV141B • CHPV141BI Packaging: • MOQ: 10 • Packaging: 100% recyclable Dimensions - mm    “  2 EATON www.eaton.com Technical Data 720132 Bussmann series 14 x 51 mm Photovoltaic fuse links Effective September 2015 Time-current curve 10000 32A 1000 25A 20A 15A Time in Seconds (s) 100 10 1 0.1 0.01 1 10 100 1000 Available current, DC-Time constant 1-3ms (Amps) Changes to the products, to the information contained in this document, and to prices are reserved; so are errors and omissions. Only order confirmations and technical documentation by Eaton is binding. Photos and pictures also do not warrant a specific layout or functionality. Their use in whatever form is subject to prior approval by Eaton. The same applies to Trademarks (especially Eaton, Moeller, and Cutler-Hammer). The Terms and Conditions of Eaton apply, as referenced on Eaton Internet pages and Eaton order confirmations. Eaton EMEA Headquarters Route de la Longeraie 7 1110 Morges, Switzerland Eaton.eu © 2015 Eaton All Rights Reserved Publication No. 720132 September 2015 Eaton is a registered trademark. All other trademarks are property of their respective owners.
PV-25A14F 价格&库存
很抱歉,暂时无法提供与“PV-25A14F”相匹配的价格&库存,您可以联系我们找货
PV-25A14F
  • 10+746.2398510+96.66416
