168Q
168Q
    GREENLEECOMMUNICATIONS(格林利)
168Q 数据手册
GRIP,QUICK CHANGE 3/4 X 1/4 (POP) Quick Change Grip for Pulling3/4 IN (19.1 MM) OD Wire with3/4 IN to 1 IN (19.1 to 25.4 MM) Cat No: 168Q UPC No: 783310127932 Description • • • • Flexible shaft allows easy access to difficult and tight areas Convenient 1/4 IN quick connect receiver accepts most standard quick change accessories Multiple extensions can beeasily joined to create the perfect length for any job Capacity: Any 1/4 IN quickchange accessory 3/4 IN diameter and under Specifications • • • • • Application : For Pulling Wire, Cable Or Fish Tape Through Walls Capacity : 100.000 LB Pulling Force Size : 1/4 IN X 3/4 IN Diameter Type : Quick Change Weight : 0.060 LB
很抱歉,暂时无法提供与“168Q”相匹配的价格&库存,您可以联系我们找货
