36278
36278
    GREENLEECOMMUNICATIONS(格林利)
36278 数据手册
Tel.: USA & Canada 800-435-0786 • Fax: USA 800-451-2632, Canada 800-524-2853 International Tel.: +1-815-397-7070 • Fax: +1-815-397-9247 • www.greenlee.textron.com Knockout Punches • • • • • • R The contractor’s choice – worldwide. Unique punch profile splits slugs allowing easy slug removal. Use with manual, ratchet, hydraulic or battery-powered drivers. Uses standard Greenlee dies and draw studs. Available in sizes up thru 2.52" (64.0 mm). U.S. Patent #4,543,722. SPECIFICATIONS Capacity: Mild steel up through 10 gauge (3.5 mm). Application: Punch mild steel, aluminum, fiberglass and plastic. Hole Sizes: Conduit Sizes – Hole size is outside diameter of US conduit sizes. Example: 1/2" conduit size punch actually makes a 7/8" hole. Pg Sizes – European standard pipe sizes. ISO Sizes – International Standards Organization pipe sizes. Operation: Operate manually, or with ratchet, hydraulic or battery drivers. When used with ratchet, hydraulic or battery drivers, buy the punch and die only; the draw stud is part of the driver kit. Split slugs fall free from the die and stud. Slug is split in half as punching operation is completed. Unique Slug Buster® punch design creases slug as the punch is drawn into the die. “Custom Size” punches and dies available. See page 56 or contact your Greenlee Distributor. PUNCH UNIT REPLACEMENT PARTS Punch Unit includes: Punch, Die and Draw Stud Conduit & Cat. No. UPC No. Pipe Size Hole Size ø inch Actual ø mm Weight lbs. g Replacement Punch Cat. No. UPC No. Replacement Die Cat. No. UPC No. Replacement Manual Draw Stud Cat. No. UPC No. Pg ISO 06727 06727 - - 0.492 12.5 7 12 16 1.5 0.3 137 06728 06728 06729 06729 1675AV 04218 7211EBB-15.2 31989 - - 0.598 15.2 9 - 14 2.0 0.3 137 31969 31969 32002 32002 00042 00042 35177 35177 - 7211EBB-18.6 31990 - 0.638 16.2 - 16 14 2.0 0.3 137 35163 35163 35162 35162 00042 00042 - 0.732 18.6 11 - 14 2.0 0.3 137 31970 31970 32003 32003 00042 00042 7211EBB-20.4 31991 - - 0.803 20.4 13 20 14 2.0 0.3 137 31971 31971 32004 32004 00042 00042 7211BB-1/2 31962 1/2" 7/8 0.885 22.5 16 - 10 3.5 0.3 137 721-1/2 31756 14722 14722 00042 00042 ◊ ◊ 1/2" 7/8 0.885 22.5 16 - 10 3.5 - - 721-1/2P◊ 01980 14722P◊ 01992 00042P 06678 35178 35178 - 1 1.000 25.4 - 25 14 2.0 0.5 227 35165 35165 35164 35164 249AVBB 04040 7211BB-3/4 31963 3/4" - 1.115 28.3 - - 10 3.5 0.8 363 721-3/4 31757 124AV 06972 249AVBB 04040 ◊ ◊ 3/4" - 1.115 28.3 - - 10 3.5 - - 721-3/4P◊ 01981 124AVP◊ 01993 249AVBBP◊ 01987 7211EBB-28.3 31993 - - 1.115 28.3 21 - 14 2.0 0.5 227 31973 31973 32006 32006 00042 00042 60246 60246 - 1-7/32 1.210 30.5 - - 10 3.5 0.6 273 60237 60237 36278 36278 249AVBB 04040 36508 36508 - 1-7/32 1.210 30.5 - - 14 2.0 0.6 273 36284 36284 36279 36279 00042 00042 35179 35179 - - 1.280 32.5 - 32 10 3.5 0.8 363 35169 35169 35168 35168 249AVBB 04040 7211BB-1 31964 1" - 1.362 34.6 - - 10 3.5 1 454 721-1◊ 31758 126AV 04011 249AVBB 04040 ◊ ◊ 1" - 1.362 34.6 10 - 10 3.5 - - 721-1P◊ 01982 126AVP◊ 01994 249AVBBP◊ 01987 7211EBB-37 31995 - - 1.457 37.0 29 - 10 3.5 1.2 545 31975 31975 32008 32008 249AVBB 04040 35180 35180 - - 1.595 40.5 - 40 10 3.5 1.2 545 35158 35158 35159 35159 249AVBB 04040 7211BB-1-1/4 31965 1-1/4" - 1.701 43.2 - - 10 3.5 1.3 590 721-1-1/4◊ 31759 128AV 04013 249AVBB 04040 ◊ ◊ 1-1/4" - 1.701 43.2 - - 10 3.5 - - 721-1-1/4P◊ 01983 128AVP◊ 01995 249AVBBP◊ 01987 7211EBB-47 31996 - - 1.850 47.0 36 - 10 3.5 1.9 862 31976 31976 32009 32009 304AVBB 04042 7211BB-1-1/2 31966 1-1/2" - 1.951 49.6 - - 10 3.5 2.1 953 721-1-1/2 31760 440AV 04061 304AVBB 04042 ◊ ◊ 1-1/2" - 1.951 49.6 - - 10 3.5 - - 721-1-1/2P◊ 01984 440AVP◊ 01996 304AVBBP◊ 01988 35181 35181 - 2 2.000 50.8 - 50 10 3.5 35160 35160 35161 35161 304AVBB 04042 2.3 1043 36171 36171 - 2-1/8 2.125 54.0 42 - 10 3.5 2.5 1134 36172 36172 36173 36173 304AVBB 04042 7211EBB-60 31998 - - 2.362 60.0 48 - 10 3.5 2.8 1270 31978 31978 32011 32011 304AVBB 04042 7211BB-2 31967 2" 2-3/8 2.416 61.5 - - 10 3.5 3.2 1452 721-2 31761 442AV 04063 304AVBB 04042 ◊ ◊ 2" 2-3/8 2.416 61.5 - - 10 3.5 721-2P◊ 01985 442AVP◊ 01997 304AVBBP◊ 01988 35182 35182 - - 2.520 64.0 - 63 10 3.5 35167 35167 35166 35166 304AVBB 04042 ◊ Individually Packaged in Point of Purchase clamshell for display opportunities 32 Capacity Mild Steel GA. mm - - 3.4 1542
36278 价格&库存
很抱歉,暂时无法提供与“36278”相匹配的价格&库存,您可以联系我们找货
