38506
38506
    GREENLEECOMMUNICATIONS(格林利)
    ARBORHOLESAW1/2"SHANK3FLATS
38506 数据手册
ARBOR,HOLESAW 1/2" SHANK W/3 FLATS Arbors with Replacement High-Speed Steel Pilot Drill Bits Cat No: 38506 UPC No: 783310385066 Description • • • • • The best arbor in the industry ensures a solid connectionwithout any gaps or wobbling Arbors include replaceable, high-speed steel pilot drill Pilot drills have unique split-point tip design Use with Greenlee bimetal hole saws, recessed light holesaws and carbide-grit hole saws (carbide-tipped pilot drillsold separately) Can be used with Greenlee #901 or #904 bit extensions Specifications • • • • • • • Application : Use With Greenlee Bimetal Hole Saws, Recessed Light Hole Saws And Carbide Grit Hole Saws (Carbide-Tipped Pilot Drill Sold Separately), Can Be Used With Greenlee No 901 Or 904 Bit Extensions, 1-1/4 IN - 6.000 IN (31.800 - 152.400 MM) Hole Saws And All Gree Material : High Speed Steel Pilot Drill Bit Minimum Chuck Size : 1/2 IN (12.700 MM) Package : Point of Purchase Pack Shank Diameter : 7/16 IN (11.100 MM) Type : Hex Shank Weight : 0.500 LB (227.000 GM)
38506 价格&库存
很抱歉,暂时无法提供与“38506”相匹配的价格&库存,您可以联系我们找货
