ARBOR,HOLESAW 1/2 SHANK W/3 FLATS
Arbors with Replacement High-Speed Steel Pilot Drill Bits
Cat No:
37156
UPC No:
783310371564
Description
The best arbor in the industry ensures a solid connectionwithout any gaps or wobbling
Arbors include replaceable, high-speed steel pilot drill
Pilot drills have unique split-point tip design
Use with Greenlee bimetal hole saws, recessed light holesaws and carbide-grit hole saws
(carbide-tipped pilot drillsold separately)
Can be used with Greenlee #901 or #904 bit extensions
Specifications
Application : Use With Greenlee Bimetal Hole Saws, Recessed Light Hole Saws And Carbide Grit
Hole Saws (Carbide-Tipped Pilot Drill Sold Separately), Can Be Used With Greenlee No 901 Or
904 Bit Extensions, 1-1/4 IN - 6.000 IN (31.800 - 152.400 MM) Hole Saws And All Gree
Material : High Speed Steel Pilot Drill Bit
Minimum Chuck Size : 1/2 IN (12.700 MM)
Package : Standard Pack
Shank Diameter : 7/16 IN (11.100 MM)
Type : Hex Shank
Weight : 0.500 LB (227.000 GM)
很抱歉,暂时无法提供与“37156”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+365.541091+47.38109
