645-1-1/8
645-1-1/8
    GREENLEECOMMUNICATIONS(格林利)
    CUTTER CARBIDE
645-1-1/8 数据手册
CUTTER, CARBIDE (1-1/8"). Quick Change Stainless Steel Hole Cutters Cat No: 645-1-1/8 UPC No: 783310056973 Description • • • • • • • • Cuts stainless steel quickly and easily Quick Change arbor allows you to change cutter heads with a simple push and a turn. Use the same arbor for different size cutting heads Removable cutter heads available in sizes from 5/8 IN through 3 IN Flange stop prevents over-drilling Ejector spring on all sizes above 3/4 IN makes removal of slug easier Replaceable, cobalt-steel pilot drill with split-point tip to prevent walking Precision carbide teeth for optimum performance and durability Minimum chuck size of 3/8 IN Specifications • • • • • Application : For 3/4 IN Conduit Chuck Size : 3/8 IN Material : Carbide Tip Size : 1-1/8 IN Type : Quick Change
645-1-1/8 价格&库存
很抱歉,暂时无法提供与“645-1-1/8”相匹配的价格&库存,您可以联系我们找货
