925-1-1/8
925-1-1/8
    GREENLEECOMMUNICATIONS(格林利)
    CUTTERPKGHSS1.125"
925-1-1/8 数据手册
CUTTER PKG,HSS 1.125" Ultra Cutters Cat No: 925-1-1/8 UPC No: 783310101581 Description • • • • • • • • "Lasts 10 times longer thanstandard hole saws Precision-ground teeth cutsmooth, burr-free holes with ease 1/4 IN (6.35 mm) capacity Durability and speed provide low cost per hole Split-point pilot drill prevents ?walking"" - makes accurate hole placement easy Spring-loaded slug ejectorsaves time No tool required to changecutter sizes Less chance of broken teeth because the saw body is machined out of solid, high-speed steel " Specifications • • • • Application : For 3/4 IN Conduit Hole Diameter : 1-1/8 IN Material : High Speed Steel Type : Ultra
925-1-1/8 价格&库存
很抱歉,暂时无法提供与“925-1-1/8”相匹配的价格&库存,您可以联系我们找货
