PV-20A14L-T
PV-20A14L-T
    EATON(伊顿)
    FUSE20AMP1500VSOLARTAGFUSE
PV-20A14L-T 数据手册
BUSSMANN Technical Data 720139 Effective September 2015 Supersedes September 2012 SERIES Bussmann series 14 x 65 mm Photovoltaic fuse links Product description Eaton’s Bussmann series range of 14 x 65 mm fuse links is specifically designed for protecting and isolating photovoltaic strings. These fuse links are capable of interrupting low overcurrents associated with faulted PV systems (reverse current, multi-array fault). Technical Data 720139 Bussmann series 14 x 65 mm Photovoltaic fuse links Effective September 2015 Catalogue symbol • Cylindrical: PV-(amp rating)A14LF • Cylindrical with tags: PV-(amp rating)A14L-T • Cylindrical with 10 mm fixings: PV-(amp rating)A14LF10F Fuse size • 14 x 65 mm Technical data • Rated voltage: • 1300 V d.c. (25 and 32 A) • 1500 V d.c. (15 and 20 A) • Rated current: 15 to 32 A • Breaking capacity: 10 kA • Class of operation: gPV • Minimum interrupting rating: 2 x In • PV fuse coordination with thin film cells 4”, 5” and 6” crystalline silicon cells • Time constant: 1-3 ms Standards/Approvals • IEC 60269-6 • UL 2579 (File number E335324) • RoHS compliant Packaging • MOQ: 10 Accessories • Fuse clips • 5592-01 for -LF • 5960-07 and 5960-09 for -10F Table 1. Technical data Catalogue number Energy integrals I²t (A²s) Cylindrical Cylindrical with Cylindrical with tags 10mm fixings Rated current (A) PV-15A14LF PV-20A14LF PV-25A14LF PV-32A14LF PV-15A14L-T PV-20A14L-T PV-25A14L-T PV-32A14L-T 15 20 25 32 2 PV-15A14LF10F PV-20A14LF10F PV-25A14LF10F PV-32A14LF10F EATON www.eaton.com Rated voltage (V d.c.) 1500 1300 Watts loss (W) Pre-arcing Total at rated voltage 0.8 In In 14 34 65 105 160 400 550 900 3.2 3.6 4.1 5.7 5.8 6.5 7.5 10.4 Bussmann series 14 x 65 mm Photovoltaic fuse links Technical Data 720139 Effective September 2015 Dimensions - mm Cylindrical PV-(amp rating)A14LF Cylindrical with Tags PV-(amp rating)A14L-T Cylindrical with 10mm Fixings PV-(amp rating)A14LF10F EATON www.eaton.com 3 Technical Data 720139 Bussmann series 14 x 65 mm Photovoltaic fuse links Effective September 2015 Time current curve 10000 1000 32A 100 7LPHLQVHFRQGV V 25A 20A 15A 10 1 0.1 0.01 1 10 100 1000 $YDLODEOHFXUUHQW'&7LPHFRQVWDQWPV $PSV Changes to the products, to the information contained in this document, and to prices are reserved; so are errors and omissions. Only order confirmations and technical documentation by Eaton is binding. Photos and pictures also do not warrant a specific layout or functionality. Their use in whatever form is subject to prior approval by Eaton. The same applies to Trademarks (especially Eaton, Moeller, and Cutler-Hammer). The Terms and Conditions of Eaton apply, as referenced on Eaton Internet pages and Eaton order confirmations. Eaton EMEA Headquarters Route de la Longeraie 7 1110 Morges, Switzerland Eaton.eu © 2015 Eaton All Rights Reserved Publication No. 720139 September 2015 Eaton is a registered trademark. All other trademarks are property of their respective owners.
PV-20A14L-T 价格&库存
很抱歉,暂时无法提供与“PV-20A14L-T”相匹配的价格&库存,您可以联系我们找货
