BUSSMANN
Technical Data 720139
Effective September 2015
Supersedes September 2012
SERIES
Bussmann series
14 x 65 mm Photovoltaic fuse links
Product description
Eaton’s Bussmann series range of 14 x 65 mm
fuse links is specifically designed for protecting
and isolating photovoltaic strings. These fuse
links are capable of interrupting low overcurrents
associated with faulted PV systems (reverse
current, multi-array fault).
Bussmann series
Catalogue symbol
Cylindrical: PV-(amp rating)A14LF
Cylindrical with tags: PV-(amp rating)A14L-T
Cylindrical with 10 mm fixings: PV-(amp rating)A14LF10F
Fuse size
14 x 65 mm
Technical data
Rated voltage:
1300 V d.c. (25 and 32 A)
1500 V d.c. (15 and 20 A)
Rated current: 15 to 32 A
Breaking capacity: 10 kA
Class of operation: gPV
Minimum interrupting rating: 2 x In
PV fuse coordination with thin film cells 4”, 5” and 6” crystalline
silicon cells
Time constant: 1-3 ms
Standards/Approvals
IEC 60269-6
UL 2579 (File number E335324)
RoHS compliant
Packaging
MOQ: 10
Accessories
Fuse clips
• 5592-01 for -LF
5960-07 and 5960-09 for -10F
Table 1. Technical data
Catalogue number
Energy integrals I²t (A²s)
Cylindrical
Cylindrical with Cylindrical with
tags
10mm fixings
Rated current
(A)
PV-15A14LF
PV-20A14LF
PV-25A14LF
PV-32A14LF
PV-15A14L-T
PV-20A14L-T
PV-25A14L-T
PV-32A14L-T
15
32
2
PV-15A14LF10F
PV-20A14LF10F
PV-25A14LF10F
PV-32A14LF10F
EATON www.eaton.com
Rated voltage
(V d.c.)
1500
1300
Watts loss (W)
Pre-arcing
Total at rated
voltage
0.8 In
In
14
34
65
105
160
400
550
900
3.2
3.6
4.1
5.7
5.8
6.5
7.5
10.4
Bussmann series
Dimensions - mm
Cylindrical PV-(amp rating)A14LF
Cylindrical with Tags PV-(amp rating)A14L-T
Cylindrical with 10mm Fixings PV-(amp rating)A14LF10F
EATON www.eaton.com
3
Bussmann series
Time current curve
10000
1000
32A
100
7LPHLQVHFRQGVV
25A
20A
15A
10
1
0.1
0.01
1
10
100
1000
$YDLODEOHFXUUHQW'&7LPHFRQVWDQWPV$PSV
Changes to the products, to the information
contained in this document, and to prices
are reserved; so are errors and omissions.
Only order confirmations and technical
documentation by Eaton is binding. Photos
and pictures also do not warrant a specific
layout or functionality. Their use in whatever
form is subject to prior approval by Eaton.
The same applies to Trademarks (especially
Eaton, Moeller, and Cutler-Hammer). The
Terms and Conditions of Eaton apply, as
referenced on Eaton Internet pages and
Eaton order confirmations.
Eaton
EMEA Headquarters
Route de la Longeraie 7
1110 Morges, Switzerland
Eaton.eu
© 2015 Eaton
All Rights Reserved
Publication No. 720139
September 2015
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“PV-32A14L-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 3+453.84786
- 10+429.55704
