CARBIDE CUTTER SETS
INCLUDING 7/8" - 2 1/2"
FASTER. SAFER. EASIER.®
GREENLEE’S CARBIDE CUTTERS
CONTINUE TO DELIVER THE LOWEST COST PER HOLE!
EVERYTHING YOU NEED TO GET THE JOB DONE
• Complete solutions for 1/2” to 2” conduit
• Fast, accurate holes in stainless steel, mild steel, iron, copper, brass, aluminium,
fiberglass and plastic sheet
• Longer tool life - less friction, torque and heat
CARBIDE CUTTER SET
CAT.
NO.
628 - INCLUDES 7/8" - 2 1/2" CUTTERS
FASTER
SAFER
EASIER
• Split point, cobalt-steel
pilot drill eliminates
walking and penetrates
quickly
• Flange Stop for Safety –
prevents over-drilling
• Optimized carbide design
requires less force
• Reduced torque minimizes
muscle exertion
• Ejector spring allows
automatic slug removal
with every cut
• Precision engineered
tungsten carbide teeth
for fast cutting of round;
burr-free holes
PRODUCTS SHOWN AT ACTUAL SIZE
7/8"
1 3/8"
1 1/8"
2"
1 3/4"
2 1/2"
QUICK CHANGE
CARBIDE CUTTER SET
Change cutter sizes with a simple push and turn. Reduce cost by replacing cutter heads only.
CAT.
NO.
648 - INCLUDES 7/8" - 2 1/2" CUTTERS
FASTER
SAFER
EASIER
quickly
requires less force
muscle exertion
with every cut
burr-free holes
2 1/2"
2"
1 3/4"
1 3/8"
1 1/8"
7/8"
QUICK CHANGE CARBIDE HOLE CUTTERS
PIPE/CONDUIT
HOLE SIZE
CAT. NO.
INCH
MM
645-5/8
5/8"
645-11/16
11/16"
17.5
645-3/4
3/4"
19.0
645-13/16
13/16"
20.6
645-7/8
7/8"
22.2
645-1
1"
25.4
645-1-1/16
1-1/16"
27.0
645-1-1/8
1-1/8"
28.6
645-1-7/32
1-7/32"
31.0
ENTRANCE
TAP
648
SET
660
SET
655
SET
15.9
645-1-1/4
1-1/4"
31.8
645-1-5/16
1-5/16"
33.3
645-1-3/8
1-3/8"
34.9
645-1-7/16
1-7/16"
36.5
3/8"
1/2"
1/2"
3/4"
3/4"
1"
1"
CAT. NO.
645-1-1/2
1-1/2"
38.1
645-1-3/4
1-3/4"
44.4
1-1/4"
1-1/2"
645-2
2"
50.8
645-2-1/8
2-1/8"
54.0
645-2-1/4
2-1/4"
57.2
645-2-3/8
2-3/8"
60.3
645-2-1/2
2-1/2"
63.5
645-2-5/8
2-5/8"
66.7
645-3
3"
76.2
QUICK CHANGE ARBORS
FOR 645 CUTTERS
1-1/4"
1-1/2"
HOLE
SIZE
648
SET
660
SET
655
SET
645-011
Up to 2"
645-022
2-1/2" - 3"
REPLACEMENT PILOT DRILLS FOR 645 ARBORS
2"
645-001
Up to 2"
Use with 645-011 Arbor
645-002
2-1/2" - 3"
Use with 645-022 Arbor
2"
2-1/2"
2-1/2"
PIPE/CONDUIT
HOLE SIZE
CAT. NO.
INCH
MM
ENTRANCE
TAP
628
SET
635
SET
625-3/4
3/4"
19.0
3/8"
1/2"
625-7/8
7/8"
22.2
1/2"
3/4"
1"
25.4
3/4"
1"
625-1
625-1-1/8
1-1/8"
28.6
625-1-7/32
1-7/32"
31.0
625-1-3/8
1-3/8"
34.9
1"
625-1-1/2
1-1/2"
38.1
625-1-3/4
1-3/4"
44.4
1-1/4"
2"
50.8
1-1/2"
2-1/2"
63.5
2"
625-2
625-2-1/2
1-1/4"
REPLACEMENT PILOT DRILLS FOR 625 CUTTERS
625-001
Use with 625 Cutters up to 2"
625-002
Use with 625-2-1/2" Only
ORDERING INFORMATION
CAT. NO.
628
648
UPC
DESCRIPTION
06400
Carbide Cutter Set, 8pc
06401
Carbide Cutter Set,
Quick Change, 8pc
SIZES
HOLE SIZES
PIPE/CONDUIT
SIZES
6
7/8", 1-1/8", 1-3/8",
1-3/4", 2", 2-1/2"
1/2", 3/4", 1", 1-1/4",
1-1/2", 2"
Lubrication during drilling helps extend the
life of cutting tools. Greenlee recommends
the use of 462 Series Cutting Oil, available in
quart (462-Q) and gallon (462-1) sizes.
www.greenlee.com
MA6518 03/16
4455 Boeing Drive • Rockford, IL 61109-2988 • USA • 815-397-7070
©2016 Greenlee Textron Inc. • An ISO 9001 Company • Printed in USA
Greenlee Textron Inc. is a subsidiary of Textron Inc.
很抱歉,暂时无法提供与“625-7/8”相匹配的价格&库存,您可以联系我们找货
