CUTTER, CARBIDE (1-7/32")
Quick Change Stainless Steel Hole Cutters
Cat No:
645-1-7/32
UPC No:
783310056980
Description
Cuts stainless steel quickly and easily
Quick Change arbor allows you to change cutter heads with a simple push and a turn. Use the
same arbor for different size cutting heads
Removable cutter heads available in sizes from 5/8 IN through 3 IN
Flange stop prevents over-drilling
Ejector spring on all sizes above 3/4 IN makes removal of slug easier
Replaceable, cobalt-steel pilot drill with split-point tip to prevent walking
Precision carbide teeth for optimum performance and durability
Minimum chuck size of 3/8 IN
Specifications
Chuck Size : 3/8 IN
Material : Carbide Tip
Type : Quick Change
很抱歉,暂时无法提供与“645-1-7/32”相匹配的价格&库存,您可以联系我们找货
