BIT,NAILEATER 11/16 (.687) X 8.00(62PTS)
Nail Eater Extreme
Cat No:
62PTS-11/16
UPC No:
783310317906
Description
"Improved cutting edge provides 30% longer life span
Patented new design for improved cutting and cleaner holes
Self-feeding screw point draws bit through wood
Unique patented design cutting angle - smoother starts, reduced cutting loads
Made of super tough, heat-treated steel
cuts through nails and provides longer life
?Shorty"" bits - for working in tight places, yet still can go through three abutting 2 x 4s
See ?Bit Extensions"" if more length is required
P.O.P packaged "
Specifications
Bit Diameter : 11/16 IN (17.500 MM)
Electric Drill Required : 61 PTS - 5/8 Through 61 PTS -1, Minimum 3/8 IN Drill, All Big Shank, 1/2
IN Drill
Material : Heat Treated Steel
Overall Length : 7-5/8 IN (193.700 MM)
Shank Diameter : 7/16 IN (11.100 MM)
Shank Type : Hexagonal
Sub Brand : Nail Eater
Twist Length : 5.000 IN (127.000 MM)
Type : Extreme Shorty
Weight : 0.400 LB (182.000 GM)
很抱歉,暂时无法提供与“62PTS-11/16”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+374.717951+48.49048
