925-1-7/32
925-1-7/32
    GREENLEECOMMUNICATIONS(格林利)
    CUTTERPKGHIGHSPEED1-7/32
925-1-7/32 数据手册
CUTTER PKG,HIGH SPEED 1-7/32 Ultra Cutters Cat No: 925-1-7/32 UPC No: 783310016434 Description • • • • • • • • Lasts 10 times longer than standard hole saws Precision-ground teeth cut smooth, burr-free holes with ease 1/4 IN (6.35 mm) capacity Durability and speed provide low cost per hole Split-point pilot drill prevents "walking" - makes accurate hole placement easy Spring-loaded slug ejector saves time No tool required to change cutter sizes Less chance of broken teeth because the saw body is machined out of solid, high-speed steel Specifications • • • • Hole Diameter : 1-7/32 IN Material : High Speed Steel Pipe Tap Size : 5/8 IN Type : Ultra
925-1-7/32 价格&库存
很抱歉,暂时无法提供与“925-1-7/32”相匹配的价格&库存,您可以联系我们找货
    • 1+393.202381+51.11504
