BIT,NAILEATER 5/8(.625) X 18 (66PT-5/8)
Nail Eater Extreme
Cat No:
66PT-5/8
UPC No:
783310309192
Description
"Improved cutting edge provides 30% longer life span
Patented new design for improved cutting and cleaner holes
Self-feeding screw point draws bit through wood
Unique patented design cutting angle - smoother starts, reduced cutting loads
Made of super tough, heat-treated steel
cuts through nails and provides longer life
?Shorty"" bits - for working in tight places, yet still can go through three abutting 2 x 4s
See ?Bit Extensions"" if more length is required
P.O.P packaged "
Specifications
Bit Diameter : 5/8 IN (15.900 MM)
Material : Heat Treated Steel
Overall Length : 18.000 IN (457.200 MM)
Shank Diameter : 7/16 IN (11.100 MM)
Shank Type : Hexagonal
Sub Brand : Nail Eater
Twist Length : 15.000 IN (381.000 MM)
Type : Extreme
Weight : 0.800 LB (363.000 GM)
很抱歉,暂时无法提供与“66PT-5/8”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+439.702461+56.88725
