34401
    GREENLEECOMMUNICATIONS(格林利)
34401 数据手册
BIT,STEP #1 (PKGD). Kwik Stepper® Step Bits Cat No: 34401 UPC No: 783310344018 Description • • • • Unique split-tip design penetrates through steel faster Resists walking or skidding, even on round surfaces Balanced, double-flute construction requires less pressure, does the work for you Designed and manufactured in USA. Specifications • • • • • • • • Bit Extension : 901 Capacity : Cut Up Through 3/8 IN (9.500 MM) Mild Steel, Copper, Brass,Aluminum, Wood, Plastic and Laminates Hole Size : 1/8 IN (3.200 MM), 5/32 IN (4.000 MM), 3/16 IN (4.800 MM), 7/32 IN (5.600 MM), 1/4 IN (6.400 MM), 9/32 IN (7.100 MM), 5/16 IN (7.900 MM), 11/32 IN (8.700 MM), 3/8 IN (9.500 MM), 13/32 IN (10.300 MM), 7/16 IN (11.100 MM), 15/32 IN (11.900 MM), 1/2 IN (12.7 Maximum Material Thickness : 10 GA (3.500 MM) Minimum Chuck Size : 3/8 IN (9.500 MM) Overall Length : 3-7/8/ IN (85.700 MM) Sub Brand : Kwik Stepper Type : Multi Hole
34401 价格&库存
很抱歉,暂时无法提供与“34401”相匹配的价格&库存,您可以联系我们找货
