36018
36018
    GREENLEECOMMUNICATIONS(格林利)
    BITSTEP97MM
36018 数据手册
BIT,STEP 9,7MM (PKGD) Kwik Stepper® Step Bit 9.7 mm Cat No: 36018 UPC No: 783310360186 Description • • • • Unique split-tip design penetrates through steel faster Resists walking or skidding, even on round surfaces Balanced, double-flute construction requires less pressure, does the work for you Designed and manufactured in USA. Specifications • • • • • • • Bit Extension : 901 Capacity : Cut Up Through 3/8 IN (9.500 MM) Mild Steel, Copper, Brass,Aluminum, Wood, Plastic and Laminates Maximum Material Thickness : 10 GA (3.500 MM) Minimum Chuck Size : 3/8 IN (9.500 MM) Overall Length : 1-7/8 IN (47.600 MM) Sub Brand : Kwik Stepper Type : Multi Hole
36018 价格&库存
很抱歉,暂时无法提供与“36018”相匹配的价格&库存,您可以联系我们找货
