OC69271-FNM
OC69271-FNM
    LAIRD(莱尔德)
    ANTBROADBANDLTEOMNI
OC69271-FNM 数据手册
OC69271 698-960 MHz/1710-2700 MHz LTE Direct Mount Omnidirectional Antenna MULTI-BAND DIRECT MOUNT OMNIDIRECTIONAL ANTENNA The OC69271 antenna is a wide band omnidirectional antenna covering the domestic LTE700/ Cellular/ PCS/AWS/MDS, WiMAX 2300/2500, and global GSM900/GSM1800/UMTS/LTE2600 bands. The antenna can be used in both indoor and outdoor applications. It comes complete with mast mounting hardware and includes a UV stable radome enclosure that provides years of use without degradation to either mechanical properties or aesthetics. MARKETS FEATURES • Applicable for both 3G and 4G solutions • Broadband wireless access service provider • Domestic LTE 700 band and Global LTE 2600 band • Campus, healthcare, or transportation terminals • Stadium, industrial plants, and processing stations • Domestic Cellular and Global GSM • WiMAX 2300/2500/2600 • Low-to-medium density, tower mounted rural locations • Weatherproof UV stable radome • Public Safety Radio • Mast mounting hardware included PARAMETER SPECIFICATION Frequency Gain 698 to 960 MHz, 1710 to 1990 MHz, 1920 to 2170 MHz, 2100 to 2500 MHz, 2500 to 2690 MHz 698 to 960 MHz - 1.5 dBi, 1710 to 2700 MHz - 3.5 dBi Average Efficiency 698 to 960 MHz - 76%, 1710 to 2700 MHz - 87% 3 dB Beamwidth - E-plane 698 to 960 MHz - 81°, 1700 to 2200 MHz - 75°, 2500 to 2700 MHz - 100° 3 dB Beamwidth - H-plane 360°, Omnidirectional Polarization Linear, Vertical Nominal Impedance 50 Ohms VSWR 698 to 960 MHz -
OC69271-FNM 价格&库存
很抱歉,暂时无法提供与“OC69271-FNM”相匹配的价格&库存,您可以联系我们找货
