PDB280-3
PDB280-3
    EATON(伊顿)
    接线端子
PDB280-3 数据手册
Technical Data 10537 Effective September 2019 Supersedes January 2019 UL Listed power distribution blocks Catalog number example: PDB323-3 is a 3-pole PDB323 Where: • The prefix “PDB323” defines the block’s lineside characteristics (i.e., one conductor port per pole that accepts 350 kcmil - #6 Cu/ Al conductors) and the loadside characteristics (i.e., six (6) conductor ports per pole that each accepts #4 - #14 Cu or #4 - #12 Al conductors). • The suffix “3” in this example defines this as a three-pole block. • See the catalog number table for details on the available lineside/loadside characteristics. How to order: Catalog symbol: • PDB___(poles) Description: Eaton’s Bussmann™ series high Short-Circuit Current Rating (SCCR) power distribution blocks provide up to 200 kA SCCR and help achieve compliance with National Electrical Code (NEC®) and OSHA requirements by resolving a common SCCR “weak link” in industrial control panels. Available in 1-, 2- and 3-pole panel mount versions with popular lineside and loadside port configurations, these blocks are UL® Listed and provide the requisite spacing between uninsulated opposite polarities or ground by meeting the UL 1953 1” through air and 2” over surface spacings required per UL 508A for feeder circuit applications and per NEC for field installations. To increase application flexibility, these blocks feature dual-wire rated ports that accept copper or aluminum conductors while retaining a UL Listed status. Optional covers are available (order separately). From the catalog number table, select the catalog number that defines the desired lineside/loadside port and conductor characteristics. Add to the catalog number the suffix that defines the desired pole configuration. Note, you must select from the available number of poles for each catalog number. These appear in the second column of the catalog number tables. Specifications: Ratings • Volts: 600 V • Amps: 175 to 310 A • SCCR: 200 kA (see table for circuit protection details) Flammability rating • UL 94 V0 Storage and operating temperature range • -4°F to 248°F (-20°C to 120°C) Agency information • UL 1953 Listed, Guide QPQS, File E256146 • CSA® Certified, Class 6228-01, File 47235 Conductors† • Stranded 75°C copper and aluminum • Higher temperature rated conductors permitted with appropriate derating † As specified in the catalog number table. Technical Data 10537 UL Listed power distribution blocks Effective August 2016 Catalog numbers: Lineside Line/load port configuration No. of poles 1, 3 1, 3 1, 3 1, 2, 3 1, 3 Current rating (A) 175 175 175 175 Wire size (Str/ferrule unless noted)* Wires per port 2/0 - #1 Cu/Al (Str) 1 #2 - #3 Cu/Al 1 #4 - #8 Cu/Al 1 #10 - #12 Al (Str) 1 #10 - #14 Cu 1 #4 - #8 Cu/Al 2 #10 - #14 Cu 2 2/0 - #1 Cu/Al (Str) #2 - #3 Cu/Al #4 - #8 Cu/Al 1-2 #10 - #14 Cu 1-2 2/0 - #1 Cu/Al (Str) 1 1 #4 - #8 Cu/Al 1 #10 - #12 Al (Str) 1 #10 - #14 Cu 1 #4 - #8 Cu/Al 2 #10 - #14 Cu 2 1 #4 - #6 Cu/Al (Str) 1 1 #8 Cu 1 #8 Al (Str) 1-2 #10 - #14 Cu 1-2 2.3 (20) 1/4-20 x 3/4” Stud — — 1 #4 - #8 Cu/Al 1-2 1 4.0 (35) 13.6 (120) 13.6 (120) 13.6 (120) 1 1 #10 - #14 Cu 1-2 1 #4 - #6 Cu/Al (Str) 1 #2 - #3 Cu/Al 1 #8 Al (Str) 1-2 #4 - #8 Cu/Al 1-2 #10 - #12 Al (Str) 1 #10 - #14 Cu 1-2 1/0 Cu/Al (Str) 1-2 1/0 Cu/Al (Str) #1 - #6 Cu/Al 350kcmil - 2/0 Cu/Al (Str) 310 12.4 (110)†† 2/0 - #1 Cu/Al (Str) 350kcmil - 2/0 Cu/Al (Str) 1, 3 1 1 310 Wires per Torque port N•m (Lb-in) #2 - #3 Cu/Al #2 - #3 Cu/Al #1 - #6 Cu/Al 1, 3 Torque Ports/ N•m (Lb-in) pole 2/0 - #1 Cu/Al (Str) 350kcmil - 2/0 Cu/Al (Str) 310 Loadside Wire size (Str/ferrule unless noted)* 13.6 (120) 31.1 (275)† #1 - #6 Cu/Al 1 1-2 1 1-2 31.1 (275) † 1 1-2 1 31.1 (275) † 1/0 Cu/Al (Str) 1 1-2 1-2 1 4.0 (35) 2.8 (25) 2.8 (25) 4.0 (35) 2.3 (20) #8 Al (Str) 1-2 #8 Cu 1 2.8 (25) 1 4.0 (35) #10 - #12 Cu 1 #10 - #14 Cu 2 1 #8 Al (Str) 1-2 1 2.8 (25) 1 4.0 (35) 2.3 (20) 1-2 1 #4 - #8 Al (Str) 1 #6 - #8 Al (Str) 2 #4 Cu 1 #6 Cu 1-2 PDB220-_ 1 200 PDB280-_ 6 200 PDB321-_ 6 200 PDB323-_ 12 200 PDB370-_ 200 PDB371-_ 4.0 (35) #8 Cu #10 - #14 Cu 200 2.3 (20) #10 - #12 Al (Str) #2 - #3 Cu/Al (Str) 4 4.0 (35) #10 - #12 Al (Str) #4 - #6 Cu/Al (Str) PDB204-_ 4.0 (35) 1 1 200 4.0 (35) 1 1-2 1 13.6 (120) #8 Cu #10 - #14 Cu Max SCCR Catalog (kA)** number 12.4 (110)†† #10 - #12 Al (Str) #4 - #6 Cu/Al (Str) Ports/ pole 5.6 (50) 5.1 (45) #8 Cu 1-2 #10 - #12 Cu 1-2 #14 Cu 2 1/0 - #3 Cu/Al (Str) 1 5.6 (50) #4 - #6 Cu/Al 1 5.1 (45)†† 6 4.5 (40) 4.0 (35) #8 Cu/Al 1 4.5 (40)†† #10 - #12 Cu 1 4.0 (35)†† #6 - #14 Cu 2 #4 - #6 Al (Str) 2 3 13.6 (120) * 75°C wire (higher temperature rated wire acceptable with appropriate derating). Using a ferrule on a stranded conductor requires a correctly sized UL Listed ferrule (customer supplied) applied according to the manufacturer’s specifications. Ferrule ratings apply to copper wire only. ** See pages 4 and 5 for the tested upstream overcurrent protective devices necessary for achieving these SCCRs. † Torque rating for dual wire and ferrule application is 30.5 N•m (270 Lb-in). †† Torque rating for ferrule application is 13.6 N•m (120 Lb-in). 2 Eaton.com/bussmannseries Technical Data 10537 UL Listed power distribution blocks Effective August 2016 Features and benefits • • High SCCRs up to 200 kA, assist in achieving high SCCR for a control panel per NEC and UL 508A requirements. • In compliance with UL 1953 minimum spacing requirements for industrial control panel feeder and branch circuits. • Ferrule terminal application Optional covers available to reduce the risk of accidental contact with energized components. • Bussmann series PDB power distribution blocks are rated for use with UL Listed ferrules (see catalog number table for details). • Ferrule applications allow for the use of a broader range of conductor stranding and simulate a more efficient, solid wire connection with the PDB terminal port. • Always use UL Listed ferrules in accordance with the manufacturer’s specifications and instructions. Dual wire port application • Dual wire applications are only viable when using two wires of the same size, stranding, and insulating and conductor material in the same port. Rated for dual wire port application to increase the possible number of lineside and loadside connections. E.g., PDB220 can accept two wires into the lineside port (#4 - #14 Cu, #4 - #8 Al) and two wires per port (eight connections per pole total) on the loadside lug (#8 - #14 Cu, #8 Al). Selecting SCCR power distribution blocks and terminal blocks Short-circuit current rated power distribution blocks Bussmann series power distribution blocks have three distinct styles to match different application needs. There are the PDBFS_ and PDB_ high short-circuit current rated power distribution blocks and the 16_ power terminal blocks. The differences are whether the power distribution blocks are enclosed or not, and whether they are UL 1953 Listed power distribution blocks or UL 1059 Recognized power terminal blocks, which have different minimum spacing requirements. The table on this page will assist you in selecting which block is right for your application. (NEC 670.3(A)), and HVAC equipment (NEC 440.4(B)) is required by the NEC. Power distribution and terminal blocks not marked with a component SCCR are typically one of the weakest links in a control panel’s equipment SCCR and may limit the equipment SCCR to no more than 10 kA. The PDBFS_ and PDB_ products have the increased spacing required for use in feeder circuits of equipment listed to UL 508A (UL 1059 terminal blocks must be evaluated for proper spacings). Also, for building wiring systems, the PDBFS_ and PDB_ power distribution blocks can be used to meet the 2014 NEC requirements in section 376.56(B) for power distribution blocks in wireways. Why these are important Per the NEC and OSHA, equipment cannot be installed in an electrical system at a location where the available fault (short-circuit) current is greater than the equipment’s SCCR. Further, equipment SCCRs are required in the 2014 NEC and for UL 508A Listed control panels. Marking the equipment SCCR on control panels (NEC 409.110), industrial machinery electrical panels See the last page of this data sheet for SCCR tools and resources to help you further understand and solve your SCCR needs. Selection table This table provides an overview of the three Bussmann series power distribution and terminal blocks mentioned above. For details on the PDBFS blocks, see data sheet number 10536. For the 16_ blocks, see data sheet numbers 10533 (UL Recognized power distribution blocks), 10534 (splicer blocks) and 10535 (stud blocks). Catalog symbol PDBFS_ PDB_ 16_ * ** *** † †† UL status UL 1953 Listed power distribution blocks UL 1953 Listed power distribution blocks UL 1059 Recognized terminal blocks Enclosed High SCCR* Spacing ** 1” air, 2” surface Yes*** Yes Yes Yes Yes Yes Yes No† Yes Yes Yes Yes Yes Yes, with optional cover No† Yes No†† Yes No†† Yes No UL 508A panel branch circuit UL 508A panel feeder circuit Wireways HVAC NEC 376.56(B) UL 1995 (requires UL 1953) When protected by proper fuse class with maximum ampere rating specified or smaller. For details, see PDB and TB minimum spacing requirements for equipment table below. IP20 finger-safe under specific conditions, see data sheet no. 10536, page 5. Optional covers are available. No, except: Yes, if single pole units installed with proper spacings. Power distribution and terminal block minimum spacing requirements for equipment Spacing between live parts of opposite polarity UL standard 508A feeder circuits 508A branch circuits 1995 HVAC Through air @ 600 V 1” 3/8” 3/8” Over surface @ 600 V 2” 1/2” 1/2” Spacing between live parts and grounded parts or enclosure @ 600 V 1” 1/2” 1/2” Note: Refer to specific UL standards for complete spacing details. Eaton.com/bussmannseries 3 Technical Data 10537 UL Listed power distribution blocks Effective September 2019 Upstream fusing for SCCR and minimum enclosure data This table contains the tested SCCR levels for each PDBFS power distribution block using the specified lineside and loadside conductors and Bussmann series Class J, RK1, RK5 and T fuses. Using these tested SCCR levels also requires the power distribution block be installed in an enclosure with the minimum size indicated for each catalog number. Conductors (AWG or kcmil) Catalog number Lineside Loadside G SC (480 V) PDB204-1, -3 2/0 - #8 PDB220-1, -3 2/0 - #8 PDB280-1, -3 2/0 - #8 PDB321-1, -2, -3 2/0 - #8 PDB323-1, -3 350 - #4 PDB370-1, -3 350 - #4 PDB371-1, -3 350 - #4 2/0 - #8 #4 - #12 #4 - #14 Stud #4 - #12 #4 - #14 #4 - #8 #4 - #12 #4 - #8 #4 - #14 1/0 - #6 1/0 - #12 — — 60 — — 60 — 60 — 60 — 60 Fuse class and maximum amps* RK1 RK5 J LPN-RK (250 V) FRN-R (250 V) LPJ LPS-RK (600 V) FRS-R (600 V) 200 200 175 200 400 175 400 175 400 175 400 175 100 100 100 100 200 100 200 100 200 100 200 100 Ampacities 75°C per NEC Table 310.16 and UL 508A Table 28.1. * Class CC 30 A (LP-CC-30, FNQ-R-30, KTK-R-30) or less are suitable for all SCCRs in this table. 4 Eaton.com/bussmannseries 60 60 30 60 100 30 100 30 100 30 100 30 T JJN (300 V) JJS (600 V) SCCR 200 200 175 200 400 175 400 175 400 175 400 175 200 kA 200 kA 100 kA 200 kA 200 kA 100 kA 200 kA 100 kA 200 kA 100 kA 200 kA 100 kA Minimum enclosure size (in) 16 x 16 x 6.75 16 x 16 x 6.75 16 x 16 x 6.75 24 x 20 x 6.75 24 x 20 x 6.75 24 x 20 x 6.75 24 x 20 x 6.75 Technical Data 10537 UL Listed power distribution blocks Effective September 2019 Upstream circuit breakers for SCCR and minimum enclosure data This table contains the tested SCCR levels for each PDB power distribution block using the specified lineside and loadside conductors and Eaton circuit breakers. Using these tested SCCR levels also requires the power distribution block be installed in an enclosure with the minimum size indicated for each catalog number. PDB_ SCCR as rated with Eaton circuit breakers Catalog no. PDB220 PDB321 Suitable copper conductors kcmil/AWG Lineside Loadside #4 - #10 65 480 2/0 - #8 #12 22 480 2/0 - #8 #14 14 480 2/0 - #8 #4 - #10 65 480 2/0 - #8 #12 22 480 2/0 - #8 #14 14 480 350 - #4 #4 - #6 65 480 JGH250, J250H 250 350 - #4 #8 42 480 250 350 - #4 #10 14 480 JGH250, J250H JGH250, J250H, JGE250, J250E, JGS250, J250S, 350 - #4 350 - #4 #4 - #6 #8 #10 #8 #10 #4 - #6 #8 65 42 25 50 25 65 42 350 - #4 #10 14 350 - #4 350 - #4 #4 - #6 #8 #10 #4 - #6 #8 65 42 25 50 42 350 - #4 #10 14 350 - #4 #4 - #6 #8 #10 65 50 25 350 - #4 350 - #4 PDB371 Volts max Overcurrent protection circuit breaker required Type Max amp EGC125, E125C, EGH125, E125H, PDG13P, 125 PDG13M EGC125, E125C, EGE125, E125E, EGS125, E125S, EGH125, E125H, PDG13P, PDG13F, 125 PDG13G, PDG13M EGC125, E125C, EGB125, E125B, EGE125, E125E, EGS125, E125S, EGH125, E125H, 125 PDG13P, PDG13C, PDG13F, PDG13G, PDG13M EGC125, E125C, EGH125, E125H, PDG13P, 125 PDG13M EGC125, E125C, EGE125, E125E, EGS125, E125S, EGH125, E125H, PDG13P, PDG13F, 125 PDG13G, PDG13M EGC125, E125C, EGB125, E125B, EGE125, E125E, EGS125, E125S, EGH125, E125H, 125 PDG13P, PDG13C, PDG13F, PDG13G, PDG13M 2/0 - #8 PDB323 PDB370 SCCR, RMS Sym, kA Minimum enclosure size (in.) 16 x 16 x 6.75 24 x 20 x 6.75 250 24 x 20 x 6.75 480 JGC250, J250C, JGU250, J250U, JGX250, J250X 250 480 480 250 250 480 JGH250, J250H JGH250, J250H JGH250, J250H, JGE250, J250E, JGS250, J250S, 480 JGC250, J250C, JGU250, J250U, JGX250, J250X 250 480 480 250 250 480 JGH250, J250H JGH250, J250H JGH250, J250H, JGE250, J250E, JGS250, J250S, 480 JGC250, J250C, JGU250, J250U, JGX250, J250X 250 250 250 Eaton.com/bussmannseries 24 x 20 x 6.75 24 x 20 x 6.75 5 Technical Data 10537 UL Listed power distribution blocks Effective September 2019 Dimensions — in (mm) Catalog No. PDB204-3, PDB220-3, PDB323-3, PDB370-3, PDB323-1, PDB370-1, PDB204-1, PDB220-1, PDB321-1 PDB321-2 PDB321-3 Width A 4.25 (108) 6.30 (160) 1.98 (50) 1.07 (27) 1.98 (50) 3.60 (91) 5.20 (132) PDB280-3 PDB371-3 PDB371-1 PDB280-1 Length B 2.88 (73) 5.50 (140) 4.00 (102) 2.88 (73) 4.00 (102) 4.00 (102) 4.00 (102) PDB204 C 2.13 (54) 3.70 (94) 3.33 (84) 1.75 (44) 3.33 (84) 3.33 (84) 3.33 (84) Height D 1.62 (41) 3.25 (83) — — — 1.62 (41) 3.23 (82) E 2.25 (57) 4.75 (121) 3.37 (86) 2.25 (57) 3.37 (86) 3.37 (86) 3.37 (86) PDB220 C C Lineside B Loadside A Lineside E F F B Loadside Loadside D A A D Lineside B B PDB280 C Lineside E Loadside F A B Loadside A Loadside A E D B 6 F (Hole) 0.22 (6) 0.22 (6) 0.21 (5.3) x 0.41 (10) 0.20 (5) 0.21 (5.3) x 0.41 (10) 0.21 (5.3) x 0.41 (10) 0.21 (5) x 0.41 (10) Eaton.com/bussmannseries Lineside Lineside Technical Data 10537 UL Listed power distribution blocks Effective September 2019 PDB321 PDB323 Lineside C Loadside C B E F F Loadside Lineside Loadside A A B A E Lineside D F Loadside A D Loadside D A Lineside B Lineside E PDB370 PDB371 C C E F Lineside Loadside Lineside E Loadside F A A B B F F Loadside A Loadside D A E B D Lineside E B Lineside Eaton.com/bussmannseries 7 Technical Data 10537 UL Listed power distribution blocks Effective January 2019 Optional covers SCCR tools and resources From the table below, order the cover catalog number that matches the block catalog number. Order the quantity indicated in the “order quantity” column. E.g., the 3-pole block PDB204-3 requires ordering three CPB162-1 covers (one cover for each pole). Eaton offers many resources that help customers understand and assess their SCCR needs. Block catalog no. PDB204-1 PDB204-3 PDB220-1 PDB220-3 PDB280-1 PDB280-3 PDB323-1 PDB323-3 PDB370-1 PDB370-3 PDB371-1 PDB371-3 PDB321-1 PDB321-2 PDB321-3 Poles 1 3 1 3 1 3 1 3 1 3 1 3 1 2 3 Cover catalog no. CPB162-1 CPB162-1 CPB162-1 CPB162-1 CPB162-1 CPB162-1 CPDB-1 CPDB-1 CPDB-1 CPDB-1 CPDB-1 CPDB-1 CPDB-1* CPDB-2* CPDB-3* Order quantity 1 3 1 3 1 3 1 3 1 3 1 3 1 1 1 Please use the following whenever you have questions, concerns or just need help with SCCR ratings. • Application notes: • Developing an effective SCCR plan for facilities and purchasers of industrial equipment — publication no. 10367 • Developing an equipment SCCR standard for manufacturers of industrial equipment — publication no. 10368 • Four steps to determine equipment SCCR — publication no. 10538 • Equipment SCCR made easy brochure — publication no. 10374 • SPD (Selecting Protective Devices) handbook; over 250 pages covering the application of overcurrent protective devices, SCCR and more — publication no. 3002 * For the PDB321-_ blocks, order one cover for each block (not per pole). The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2019 Eaton All Rights Reserved Printed in USA Publication No. 10537 September 2019 8 Eaton.com/bussmannseries Eaton, Bussmann and OSCAR are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. NEC is a registered trademark of the National Fire Protection Association, Inc. UL is a registered trademark of the Underwriters Laboratories, Inc. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Follow us on social media to get the latest product and support information.
PDB280-3 价格&库存
很抱歉,暂时无法提供与“PDB280-3”相匹配的价格&库存,您可以联系我们找货
PDB280-3
    • 1+322.50960
    • 200+128.69280
    • 500+124.38360
    • 1000+122.26680
