36402
36402
    GREENLEECOMMUNICATIONS(格林利)
36402 数据手册
BIT,STEP-#2 (PKGD) Kwik Stepper® Step Bits Cat No: 36402 UPC No: 783310364023 Description • • • • Unique split-tip design penetrates through steel faster Resists walking or skidding, even on round surfaces Balanced, double-flute construction requires less pressure, does the work for you Designed and manufactured in USA. Specifications • • • • • • • • Bit Extension : 901 Capacity : Cut Up Through 3/8 IN (9.500 MM) Mild Steel, Copper, Brass,Aluminum, Wood, Plastic and Laminates Hole Size : 13/16 IN (4.800 MM), 1/4 IN (6.400 MM), 5/16 IN (7.900 MM),3/8 IN (9.500 MM), 7/16 IN (11.100 MM), 1/2 IN (12.700 MM) (12.700 MM), 9/16 IN (14.300 MM), 5/8 IN (15.900 MM), 11/16 IN (17.500 MM), 3/4 IN (19.100MM), 13/16 IN (20.600 MM) Maximum Material Thickness : 3/8 IN (9.500 MM) Minimum Chuck Size : 3/8 IN (9.500 MM) Overall Length : 3-7/16 IN (87.300 MM) Sub Brand : Kwik Stepper Type : Multi Hole
36402 价格&库存
很抱歉,暂时无法提供与“36402”相匹配的价格&库存,您可以联系我们找货
