BIT,AUGER RT 1" X 8-5/8 (POP)
"Auger Bit 1"" x 8-5/8 "
Cat No:
63RT-1
UPC No:
783310125594
Description
Patented tip design: pulls through the wood even after several holes, no pushing to finish the hole
Quick change cutting edge and feed screw no more resharpening
maximum chip removal over center flute
Easy pull back ground shaft
More durable high quality carbon alloy steel
Made stronger, lasts longer, tool steel cutting edge
Specifications
Bit Diameter : 1.000 IN
D Chain : 4
Material : Carbon Alloy Steel, Tool Steel Cutting Edge
Material Master Number : 52046222
Overall Length : 8-5/8 IN
Package : 1/Pack
Package Type : Pop
Replacement Part : PTR-1 12562 Replacememt Kit 1.000 IN IN
Shank Diameter : 7/16 IN
Shank Type : Hexagonal
Sub Brand : Nail Eater
Type : Replaceable Tip
Weight : 0.800 LB (0.318 GM)
很抱歉,暂时无法提供与“63RT-1”相匹配的价格&库存,您可以联系我们找货
