BIT,IMPACT AUGER 11/16"X24" (POP)
11/16 x 24 Impact Auger Wood Bit
Cat No:
70PT-11/16
UPC No:
783310110972
Description
Patented cutting edge for fast easy drilling of clean holes, especially in salt treatedutility poles
Made from hardened alloy steel for added toughness
The self-feeding threaded screw point draws the bit completely through the wood - no need to
push the bit while drilling
Over center flute for evacuating chips
Shaft is straightened for fewer vibrations to the hand and to help control the qualityof the hole
Cutting edge can be re-sharpened multiple times and continues to self feed
7/16 IN Hex Shank with easy to fit quick change groove for Impact Drivers
Specifications
Application : For Fast Easy Drilling Of Clean Holes, Especially In Salt Treated Utility Poles And
Wood
Bit Diameter : 11/16 IN
Material : Hardened Alloy Steel
Overall Length : 24.000 IN
Shank Diameter : 7/16 IN
Shank Type : Hexagonal
Type : Long, Impact
很抱歉,暂时无法提供与“70PT-11/16”相匹配的价格&库存,您可以联系我们找货
