645-2
645-2
    GREENLEECOMMUNICATIONS(格林利)
    CUTTERPKG2"
645-2 数据手册
CUTTER PKG (2") Quick Change Stainless Steel Hole Cutters Cat No: 645-2 UPC No: 783310057031 Description • • • • • • • • Cuts stainless steel quickly and easily Quick Change arbor allows you to change cutter heads with a simple push and a turn. Use the same arbor for differentsize cutting heads Removable cutter heads available in sizes from 5/8 IN through 3 IN Flange stop prevents over-drilling Ejector spring on all sizes above 3/4 IN makes removal of slug easier Replaceable, cobalt-steel pilot drill with split-point tip to prevent walking Precision carbide teeth for optimum performance and durability Minimum chuck size of 3/8 IN Specifications • • • • • Application : For 1-1/2 IN Conduit Chuck Size : 3/8 IN Material : Carbide Tip Size : 2.000 IN Type : Quick Change
645-2 价格&库存
很抱歉,暂时无法提供与“645-2”相匹配的价格&库存,您可以联系我们找货
