MIS-1
MIS-1
    EATON(伊顿)
MIS-1 数据手册
Effective December 2015 Supersedes April 2014 Technical Data 2021 BUSSMANN SERIES KAZ and MIS 13⁄32˝ x 2˝ 600Vac KAZ actuator and MIS non time-delay pin indicating supplemental fuses Catalog symbol / color code: • KAZ •  • Black (600Vac max actuator - not a fuse) 0.25 Min. (Blown Position) (6.35) 0.063 Max. (Unblown Position) (1.60) Black (600Vac max 1 to 12A) Description: Features: KAZ is a non-fuse actuator (not a fuse) for use in parallel with a 50 amp or greater fuse to provide indication a fuse has opened by opening at 10 or more amps. The KAZ can also be applied in a 1-, 2- or 3-pole block with miniature signaling switches to provide remote status indication. KAZ (not a fuse) MIS fuses are non time-delay pin indicating supplemental fuses used to provide a visual indication of an open fuse condition. Specification: Ratings Fuse amp range MIS 1 to 12 KAZ* N/A MIS Fuse 600Vac 1 to 12A 2.0 ±0.031 (50.8±0.79) 0.406 (10.31) MIS •  KAZ Acutator Dimensions - in (mm): Interrutping rating at rated voltage 600Vac 200kA 200kA Agency information UL® CSA® – – X – • Connects in parallel with fuses having a rating of 50 amps or more • Opens at 10A or more • Use with Bussmann series signal blocks to actuate a miniature switch that closes a signal circuit when the KAZ pin indicator ejects upon opening • Gives a direct visual indication of an open fuse by the ejected, spring actuated pin • UL Listed as “fuse accessory” • Mounts in Bussman series signal blocks 2778 (1-pole), 2837 (2-pole) and 2838 (3-pole) MIS (non time-delay fuse) • Gives a direct visual indication of an open fuse by the ejected, spring actuated pin * KAZ is not a fuse. • Can be used in circuits of 600Vac or less KAZ Agency information • 200kA Interrupting rating • CE • UL Listed, Guide JDVS, File E58836 Typical applications KAZ KAZ Catalog number (not a fuse) • Large shunt-trip fused switches KAZ • Fuse-protected circuits rated 50 amps or more with shunt-trip devices MIS Catalog numbers (amps) MIS-1 MIS-2 MIS-3 MIS-4 MIS-5 MIS-8 MIS-10 MIS-12 MIS Electrical characteristics Fuse amps All % of amp rating 110% 1-5A 6-12A 150% 150% Opening time 4 kours minimum 6 minutes max 12 minutes max MIS • 480V Control circuits • PLC Circuits Recommended fuse blocks / fuseclips: Catalog No. Description 2778 1-pole block (KAZ Only) * 2837** 2-pole block (KAZ Only) * 2838** 3-pole block (KAZ Only) * 1A3400, 5956 and 5960 PCB fuseclips * See next page for details. **Includes fuseclips to hold spare KAZ. Data sheet No. 2132 Technical Data 2047 KAZ and MIS 600Vac Acutator (KAZ) and Non time-delay pin indicating supplemental fuses (MIS) Effective December 2015 Fuse block with miniature signaling switches for KAZ only Voltage • 600V Agency information • UL Recognized, Guide QEUY2, File E61918 Dimensions ± 1/31” (0.8mm) Cat. No. Poles 2778 1 2837* 2 2838* 3 Inches/(mm’s) A B 1.75 — (44.5) 5.31 4.81 (134.9) (122.2) 6.63 6.125 (168.3) (155.6) C 2.5 (63.5) 3 (76.2) 3 (76.2) Mounting data Hole C’Bore Screw 1.73 0.328 #8 0.250 — #12 * Includes fuseclips to hold spare KAZ. 3.75" C 0.250" (6.4) (95.3) B A 0.36" 1.94" (9.1) (49.2) The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2015 Eaton All Rights Reserved Printed in USA Publication No. 2011 – BU-SB14290 December 2015 Eaton, Bussmann and Low-Peak are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. UL is a registered trademark of the Underwriters Laboratories, Inc. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Follow us on social media to get the latest product and support information.
MIS-1 价格&库存
很抱歉,暂时无法提供与“MIS-1”相匹配的价格&库存,您可以联系我们找货
MIS-1
  • 10+4311.6585910+540.69027
