61/62PTS-1-1/8
61/62PTS-1-1/8
    GREENLEECOMMUNICATIONS(格林利)
    BIT NAILEATER 1-1/8" X 7.62
61/62PTS-1-1/8 数据手册
BIT,NAILEATER 1-1/8(1.125) X 7.62(61/62) Nail Eater Extreme Cat No: 61/62PTS-1-1/8 UPC No: 783310304319 Description • • • • • • • "Improved cutting edge provides 30% longer life span Patented new design for improved cutting and cleaner holes.Self-feeding screw point draws bit through wood Unique patented design cutting angle - smoother starts, reduced cutting loads Made of super tough, heat-treated steel cuts through nails and provides longer life ?Shorty"" bits - for working in tight places, yet still can go through three abutting 2 x 4s P.O.P packaged " Specifications • • • • • • • • • • Bit Diameter : 1-1/8 IN (28.600 MM) Electric Drill Required : 61 PTS - 5/8 Through 61 PTS -1, Minimum 3/8 IN Drill, All Big Shank, 1/2 IN Drill Material : Heat Treated Steel Overall Length : 7-5/8 IN (193.700 MM) Shank Diameter : 7/16 IN (11.100 MM) Shank Type : Hexagonal Sub Brand : Nail Eater Twist Length : 5.000 IN (127.000 MM) Type : Extreme Shorty Weight : 0.900 LB (409.000 GM)
61/62PTS-1-1/8 价格&库存
很抱歉,暂时无法提供与“61/62PTS-1-1/8”相匹配的价格&库存,您可以联系我们找货
