Technical Data 1028
BUSSMANN
SERIES
Effective December 2015
Supersedes March 2014
REN (250V) and RES (600V) Renewable
Class H size fuses
250V REN Catalog numbers (1-60 Amps)
REN-1
REN-6
REN-15
REN-40
REN-2
REN-7
REN-20
REN-45
REN-3
REN-8
REN-25
REN-50
REN-4
REN-10
REN-30
REN-60
REN-5
REN-12
REN-35
250V REN Carton quantity and weight
Catalog
Carton
Weight
number
qty
lbs (kg)*
REN 1–30
10
0.55 (0.249)
REN 35–60
10
1.40 (0.634)
*Weight per carton.
600V RES Catalog numbers (1-60 Amps)
RES-1
Description:
Non-current limiting, renewable 250V (REN)
and 600V (RES) Class H size fuses and fuse
links (250V LKN and 600V LKS) for use in
electrical systems where the available fault
current is less than 10,000 amps and
frequent outages dictate the economy of
these renewable type fuses.
RES-6
RES-20
RES-45
RES-2
RES-8
RES-25
RES-50
RES-3
RES-10
RES-30
RES-60
RES-4
RES-12
RES-35
RES-5
RES-15
RES-40
600V RES Carton quantity and weight
NOTE: The 70-600 amp ratings of the REN
and RES fuses are now discontinued.
Catalog
Carton
number
qty
lbs (kg)*
Suggested replacements are:
RES 1–30
10
0.18 (0.082)
RES 35–60
10
0.36 (0.163)
REN; Use 250V FRN-R Class RK5 fuses
(see data sheet No. 1020)
RES; Use 600V FRS-R Class RK5 fuses
(see data sheet No. 1018)
Replacement fuse links for all 1-600A
ratings (250V LKN and 600V LKS) will
continue to be available to service the
installed base of REN and RES fuses.
Specifications:
Ratings
Volts
REN 250Vac
RES 600Vac
Amps
1-60A
Interrupting Rating
10kA RMS Sym.
Weight
*Weight per carton.
Features
These fuses are generally sized at the amp
rating of non-inductive circuits and 300% for
motor circuits.
Recommended fuse blocks
Part number
Description
HM250
250V, 30 and 60A 1-, 2- and
3-pole open fuse blocks
HM600
600V, 30 and 60A 1-, 2 and
For details, see data sheet No. 10289.
Technical Data 1028
Renewable Class H fuses
Dimensions - in
250V REN
600V RES
5"
3"
0.81"
1.06"
5.5"
2"
0.81"
0.56"
1A to 30A
35A to 60A
35A to 60A
1A to 30A
Replacement 250V REN and 600V RES fuse links
250V LKN Fuse link catalog numbers (amps)
600V LKS Fuse link catalog numbers (amps)
LKN-1
LKN-10
LKN-60
LKN-200
LKS-1
LKS-10
LKS-50
LKS-200
LKN-1-1/2
LKN-12
LKN-70
LKN-225
LKS-2
LKS-12
LKS-60
LKS-225
LKN-2
LKN-15
LKN-75
LKN-250
LKS-2-1/2
LKS-15
LKS-70
LKS-250
LKN-3
LKN-20
LKN-80
LKN-300
LKS-3
LKS-17-1/2
LKS-80
LKS-300
LKN-4
LKN-25
LKN-90
LKN-350
LKS-4
LKS-20
LKS-90
LKS-350
LKN-5
LKN-30
LKN-100
LKN-400
LKS-5
LKS-25
LKS-100
LKS-400
LKN-6
LKN-35
LKN-110
LKN-450
LKS-6
LKS-30
LKS-110
LKS-450
LKN-7
LKN-40
LKN-125
LKN-500
LKS-7
LKS-35
LKS-125
LKS-500
LKN-8
LKN-45
LKN-150
LKN-600
LKS-8
LKS-40
LKS-150
LKS-600
LKN-9
LKN-50
LKN-175
LKS-9
LKS-45
LKS-175
250V LKN Fuse link carton quantity and weight
Carton
Weight
number
qty
lbs (kg)*
LKN 1–30
LKN 35–60
LKN 70–100
10
0.20 (0.09)
LKN 110–200
5
0.25 (0.11)
LKN 225–400
5
0.55 (0.25)
LKN 450–600
2
0.32 (0.15)
*Weight per carton.
2
600V RES Fuse link carton quantity and weight
Catalog
Eaton.com/bussmannseries
Catalog
Carton
Weight
number
qty
lbs (kg)*
LKS 1–30
LKS 35–60
LKS 65–100
10
0.02 (0.09)
LKS 110–200
5
0.25 (0.11)
LKS 225–400
5
0.55 (0.25)
LKS 450–600
2
0.32 (0.15)
*Weight per carton.
Technical Data 1028
Time-current characteristic curves – average melt
250V REN (LKN Fuse links)
Time in seconds
Current in amperes
Current in amperes
3
Technical Data 1028
600V RES (LKS Fuse links)
Time in seconds
Current in amperes
Current in amperes
4
Technical Data 1028
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this
document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical
information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of
any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any
technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2015 Eaton
All Rights Reserved
Printed in USA
Publication No. 1028 – BU-SB14109
December 2015
Eaton and Bussmann are valuable
trademarks of Eaton in the US and other
countries. You are not permitted to use the
Eaton trademarks without prior written
consent of Eaton.
Follow us on social media to get the
latest product and support information.
5
很抱歉,暂时无法提供与“RES-10”相匹配的价格&库存,您可以联系我们找货
