7211EBB-15.2
7211EBB-15.2
    GREENLEECOMMUNICATIONS(格林利)
7211EBB-15.2 数据手册
PUNCH UNT-BB 15.2MM (3/8"D/S) Slug-Buster Knockout Punches 0.492 to 2.520 Cat No: 7211EBB-15.2 UPC No: 783310319894 Description • • • • • • The contractor's choice - worldwide Unique punch profile also splits slugs for easier slug removal Use with battery-powered, hydraulic, ratchet or manual drivers Uses standard Greenlee dies and draw studs Slug Buster punches available in sizes up thru 2.52 IN (64.0 mm) U.S.Patent #4,543,722 for Slug-Buster Specifications • • • • • • • • • Application : For Punch Mild Steel, Aluminum, Fiberglass And Plastic Capacity Mild Steel : 14 GA (2.000 MM) Includes : Punch, Die And Draw Stud PG : 9 Replacement Part : 31969 UPC 31969 Punch, 32002 UPC 32002 Die And 00042 UPC 00042 Draw Stud Size : 0.598 IN (15.200 MM) Sub Brand : Slug-Buster Type : Knockout Weight : 0.300 LB (137.000 GM)
7211EBB-15.2 价格&库存
很抱歉,暂时无法提供与“7211EBB-15.2”相匹配的价格&库存,您可以联系我们找货
