7211EBB-20.4
7211EBB-20.4
    GREENLEECOMMUNICATIONS(格林利)
7211EBB-20.4 数据手册
PUNCH UNT (7211-E-BB) 20.4MM (3/8"D/S) Slug-Buster Knockout Punches 0.492 to 2.520 Cat No: 7211EBB-20.4 UPC No: 783310319917 Description • • • • • • The contractor's choice - worldwide Unique punch profile also splits slugs for easier slug removal Use with battery-powered, hydraulic, ratchet or manual drivers Uses standard Greenlee dies and draw studs Slug Buster punches available in sizes up thru 2.52 IN (64.0 mm) U.S.Patent #4,543,722 for Slug-Buster Specifications • • • • • • • • • • Application : For Punch Mild Steel, Aluminum, Fiberglass And Plastic Capacity Mild Steel : 14 GA (2.000 MM) Includes : Punch, Die And Draw Stud ISO : 20 PG : 13 Replacement Part : 31971 UPC 31971 Punch, 32004 UPC 32004 Die And 00042 00042 UPC Draw Stud Size : 0.803 IN (20.400 MM) Sub Brand : Slug-Buster Type : Knockout Weight : 0.300 LB (137.000 GM)
7211EBB-20.4 价格&库存
很抱歉,暂时无法提供与“7211EBB-20.4”相匹配的价格&库存,您可以联系我们找货
