RS63H
RS63H
    EATON(伊顿)
    RS63H
RS63H 数据手册
Technical Data 10024 Effective June 2015 Supersedes April 2013 BUSSMANN SERIES Bussmann series Red spot BS fuse holders Product description Eaton’s Bussmann series Red Spot British standard industrial fuse holders address many applications needs. They are fully shrouded for greater safety. The high resistance body material helps ensure high dielectric strength. The extremely reliable contact system ensures superior electrical conductivity. Technical Data 10024 Bussmann series Red spot BS fuse holders Effective June 2015 Catalogue symbol: • RS(amp)F: Front connected • RS(amp)P: Back stud connected • RS(amp)PH: Front/Back stud connected • RS20F: Back stud connected, flush mounted Agency information: • BS88 • IEC 60269 Technical data: • Rated voltage: 690 V a.c. (BS88 and IEC 60269) • Rated current: 20 to 400 A • Terminal conductor range: 10 to 240 mm2 • Maximum ambient operating temperature: 40oC • Protection index: IP20 Packaging: • 20 to 63 A: 10 per pack • 100 A: 5 per pack • 200 and 400 A: 1 per pack Table 1. Part numbers details Fuse holder description Colour Front connected Back stud connected 20 A 32 A 63 A 100 A 200 A 400 A RS400H Black RS20H RS32H RS63H RS100H RS200H White RS20HWH RS32HWH RS63HWH RS100HWH RS200HWH Green RS20HGN RS32HGN Grey RS20HGY Black RS20P/G RS32P RS63P RS100P RS200P White RS20P/GWH RS32PWH RS63PWH RS100PWH RS200PWH Green RS20P/GGN RS32PGN RS63PH RS100PH RS200PH Grey RS20P/GGY Front/Back stud connected Black RS20PH/G Back stud connected, flush mounted Black RS32PH White RS63PHWH RS20F White RS20FWH Green RS20FGN Grey RS20FGY Table 2. Technical data Rated current (Amps) Rated voltage (V a.c.) Agency markings Minimum conductor size Maximum conductor size Compatible fuse links Packaging 20 690 BS88 and IEC60269 1 mm2 10 mm2 NITD, NIT 10 1 mm2 16 mm2 TIA, AAO, H07-660 10 63 4 mm2 50 mm2 TIS, BAO, K07-660 10 100 6 mm2 32 70 mm2 TCP, CEO, L14-660 5 200 2 10 mm 120 mm2 TF, DD, M09-660 1 400 25 mm2 240 mm2 TM, EF, P11-660 1 2 EATON www.eaton.com RS400P RS400PH Bussmann series Red spot BS fuse holders Technical Data 10024 Effective June 2015 Weights: • RS20H: 136 grams • RS20P: 180 grams • RS20PH: 150 grams • RS20F: 210 grams • RS32H: 250 grams • RS32P: 300 grams • RS32PH: 275 grams • RS63H: 325 grams • RS63P: 450 grams • RS63PH: 380 grams • RS100H: 850 grams • RS100P: 1 kg • RS100PH: 925 grams • RS200H: 2 kg • RS200P: 2.2 kg • RS200PH: 2.4 kg • RS400H: 6.2 kg • RS400P: 7.2 kg • RS400PH: 7.7 kg Table 3. Accessories Catalogue numbers RS20LOCK RS32LOCK RS63LOCK RS100LOCK RS20RED RS32RED RS63RED RS100RED P5372-10 TCA2 RS-LOCK Description Padlockable inserts Red warning carriers Fuse link adaptor kits Pack quantity 20 10 10 10 10 10 10 1 1 1 RS-RED Compatible fuse links N/A N/A N/A N/A N/A N/A N/A N/A TIA, TIS, AAO, BAO AD, BD, CD, DD, TBC, TC, TF P5372--10 Compatible fuse holders RS20 RS32 RS63 RS100 RS20 RS32 RS63 RS100 RS100 RS400 TCA2 EATON www.eaton.com 3 Technical Data 10024 Bussmann series Red spot BS fuse holders Effective June 2015 Dimensions - mm “ “   “ 21(+2/(727$.(0 &+((6(+($'),;,1*6&5(:   7(50,1$/6$&&2002'$7( &$%/(683726TPP RS20H , 20 A, Front connected “ 7:2+2/(6  72&/($5%86+,1* &/  “    &/ 0678' “ “  RS20P, 20 A, Back stud connected 4 EATON www.eaton.com &/   21(+2/(727$.( 0&+((6(+($' ),;,1*6&5(: Bussmann series Red spot BS fuse holders Technical Data 10024 Effective June 2015 Dimensions - mm “  0678'  “ +2/(  72&/($5%86+,1*   “ “ &/  21(+2/(727$.( 0&+((6(+($' ),;,1*6&5(: ',$0(7(52)&$%/(+2/( ,1%$6(&217$&7 &/   RS20PH, 20 A, Front/Back stud connected +2/(5(48,5(',13$1(/ )25)/86+028/',1*56) 5  21(028/',1*&/,3 /,671R3 ,66833/,(':,7+ ($&+)/86+028/',1* &$55,(5$1'%$6( 7
RS63H 价格&库存
很抱歉,暂时无法提供与“RS63H”相匹配的价格&库存,您可以联系我们找货
RS63H
  • 10+1526.2837110+198.25651
RS63H
  • 1+993.35509
库存:121
