LKN-500B
LKN-500B
    EATON(伊顿)
LKN-500B 数据手册
Technical Data 1028 BUSSMANN SERIES Effective December 2015 Supersedes March 2014 REN (250V) and RES (600V) Renewable Class H size fuses 250V REN Catalog numbers (1-60 Amps) REN-1 REN-6 REN-15 REN-40 REN-2 REN-7 REN-20 REN-45 REN-3 REN-8 REN-25 REN-50 REN-4 REN-10 REN-30 REN-60 REN-5 REN-12 REN-35 - 250V REN Carton quantity and weight Catalog Carton Weight number qty lbs (kg)* REN 1–30 10 0.55 (0.249) REN 35–60 10 1.40 (0.634) *Weight per carton. 600V RES Catalog numbers (1-60 Amps) RES-1 Description: Non-current limiting, renewable 250V (REN) and 600V (RES) Class H size fuses and fuse links (250V LKN and 600V LKS) for use in electrical systems where the available fault current is less than 10,000 amps and frequent outages dictate the economy of these renewable type fuses. RES-6 RES-20 RES-45 RES-2 RES-8 RES-25 RES-50 RES-3 RES-10 RES-30 RES-60 RES-4 RES-12 RES-35 - RES-5 RES-15 RES-40 - 600V RES Carton quantity and weight NOTE: The 70-600 amp ratings of the REN and RES fuses are now discontinued. Catalog Carton number qty lbs (kg)* Suggested replacements are: RES 1–30 10 0.18 (0.082) RES 35–60 10 0.36 (0.163) • • REN; Use 250V FRN-R Class RK5 fuses (see data sheet No. 1020) RES; Use 600V FRS-R Class RK5 fuses (see data sheet No. 1018) Replacement fuse links for all 1-600A ratings (250V LKN and 600V LKS) will continue to be available to service the installed base of REN and RES fuses. Specifications: Ratings • • Volts • REN 250Vac • RES 600Vac Amps • • 1-60A Interrupting Rating • 10kA RMS Sym. Weight *Weight per carton. Features • These fuses are generally sized at the amp rating of non-inductive circuits and 300% for motor circuits. Recommended fuse blocks Part number Description HM250 250V, 30 and 60A 1-, 2- and 3-pole open fuse blocks HM600 600V, 30 and 60A 1-, 2 and 3-pole open fuse blocks For details, see data sheet No. 10289. Technical Data 1028 REN (250V) and RES (600V) Renewable Class H fuses Effective December 2015 Dimensions - in 250V REN 600V RES 5" 3" 0.81" 1.06" 5.5" 2" 0.81" 0.56" 1A to 30A 35A to 60A 35A to 60A 1A to 30A Replacement 250V REN and 600V RES fuse links 250V LKN Fuse link catalog numbers (amps) 600V LKS Fuse link catalog numbers (amps) LKN-1 LKN-10 LKN-60 LKN-200 LKS-1 LKS-10 LKS-50 LKS-200 LKN-1-1/2 LKN-12 LKN-70 LKN-225 LKS-2 LKS-12 LKS-60 LKS-225 LKN-2 LKN-15 LKN-75 LKN-250 LKS-2-1/2 LKS-15 LKS-70 LKS-250 LKN-3 LKN-20 LKN-80 LKN-300 LKS-3 LKS-17-1/2 LKS-80 LKS-300 LKN-4 LKN-25 LKN-90 LKN-350 LKS-4 LKS-20 LKS-90 LKS-350 LKN-5 LKN-30 LKN-100 LKN-400 LKS-5 LKS-25 LKS-100 LKS-400 LKN-6 LKN-35 LKN-110 LKN-450 LKS-6 LKS-30 LKS-110 LKS-450 LKN-7 LKN-40 LKN-125 LKN-500 LKS-7 LKS-35 LKS-125 LKS-500 LKN-8 LKN-45 LKN-150 LKN-600 LKS-8 LKS-40 LKS-150 LKS-600 LKN-9 LKN-50 LKN-175 -— LKS-9 LKS-45 LKS-175 — 250V LKN Fuse link carton quantity and weight Carton Weight number qty lbs (kg)* LKN 1–30 20 0.05 (0.02) LKN 35–60 20 0.20 (0.09) LKN 70–100 10 0.20 (0.09) LKN 110–200 5 0.25 (0.11) LKN 225–400 5 0.55 (0.25) LKN 450–600 2 0.32 (0.15) *Weight per carton. 2 600V RES Fuse link carton quantity and weight Catalog Eaton.com/bussmannseries Catalog Carton Weight number qty lbs (kg)* LKS 1–30 20 0.05 (0.02) LKS 35–60 20 0.02 (0.09) LKS 65–100 10 0.02 (0.09) LKS 110–200 5 0.25 (0.11) LKS 225–400 5 0.55 (0.25) LKS 450–600 2 0.32 (0.15) *Weight per carton. REN (250V) and RES (600V) Renewable Class H fuses Technical Data 1028 Effective December 2015 Time-current characteristic curves – average melt 250V REN (LKN Fuse links) Time in seconds Current in amperes Current in amperes Eaton.com/bussmannseries 3 Technical Data 1028 REN (250V) and RES (600V) Renewable Class H fuses Effective December 2015 Time-current characteristic curves – average melt 600V RES (LKS Fuse links) Time in seconds Current in amperes Current in amperes 4 Eaton.com/bussmannseries Technical Data 1028 REN (250V) and RES (600V) Renewable Class H fuses Effective December 2015 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2015 Eaton All Rights Reserved Printed in USA Publication No. 1028 – BU-SB14109 December 2015 Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. Follow us on social media to get the latest product and support information. 5
LKN-500B
1. 物料型号:BUSSMANN系列的REN(250V)和RES(600V)可再生Class H尺寸保险丝,以及250V LKN和600V LKS的保险丝链接。
2. 器件简介:这些保险丝用于电气系统中,其中可用的故障电流小于10,000安培,并且频繁的中断使得这些可再生类型的保险丝具有经济性。
3. 引脚分配:文档中没有提供具体的引脚分配信息。
4. 参数特性: - 电压:REN为250V,RES为600V。 - 电流:1-60A。 - 中断额定值:10kA RMS对称。
5. 功能详解:这些保险丝通常用于非感性电路的安培额定值,对于电机电路则为300%。所有1-600A额定值的替换保险丝链接将继续提供,以服务于已安装的REN和RES保险丝。
6. 应用信息:推荐使用HM250(250V,30和60A 1-, 2-和3-极开放式保险丝块)和HM600(600V,30和60A 1-, 2-和3-极开放式保险丝块)。
7. 封装信息:提供了REN和RES保险丝的尺寸信息,以及不同电流等级的尺寸。
8. 替换信息:70-600安培的REN和RES保险丝已停产,建议使用250V FRN-R Class RK5保险丝和600V FRS-R Class RK5保险丝作为替代。
9. 时间-电流特性曲线:提供了250V REN(LKN保险丝链接)和600V RES(LKS保险丝链接)的平均熔断时间-电流特性曲线。
LKN-500B 价格&库存
很抱歉,暂时无法提供与“LKN-500B”相匹配的价格&库存,您可以联系我们找货
LKN-500B
  • 2+919.799912+119.14626
