71PT-11/16
71PT-11/16
    GREENLEECOMMUNICATIONS(格林利)
71PT-11/16 数据手册
BIT,IMPACT AUGER 11/16"X30" (POP) 11/16 x 30 Impact Auger Wood Bit Cat No: 71PT-11/16 UPC No: 783310111009 Description • • • • • • • Patented cutting edge for fast easy drilling of clean holes, especially in salt treatedutility poles Made from hardened alloy steel for added toughness The self-feeding threaded screw point draws the bit completely through the wood - no need to push the bit while drilling Over center flute for evacuating chips Shaft is straightened for fewer vibrations to the hand and to help control the qualityof the hole Cutting edge can be re-sharpened multiple times and continues to self feed 7/16 IN Hex Shank with easy to fit quick change groove for Impact Drivers Specifications • • • • • • • Application : For Fast Easy Drilling Of Clean Holes, Especially In Salt Treated Utility Poles And Wood Bit Diameter : 11/16 IN Material : Hardened Alloy Steel Overall Length : 30.000 IN Shank Diameter : 7/16 IN Shank Type : Hexagonal Type : Long, Impact
71PT-11/16 价格&库存
很抱歉,暂时无法提供与“71PT-11/16”相匹配的价格&库存,您可以联系我们找货
71PT-11/16
    • 1+755.470361+97.74889
