CCPLP-2-20G-S
CCPLP-2-20G-S
    EATON(伊顿)
    FUSELPCCPCLASSG20AP-SCREW
CCPLP-2-20G-S 数据手册
Technical Data 10372 Effective December 2015 BUSSMANN Effective June, 2015 SERIES Low Profile Compact Circuit Protector (CCPLP) UL Class G, CC, midget and IEC 10x38mm aM/gG fused disconnect switches Contents Description Page Description Page Catalog symbol 2 Features 3 Description 2 Available Bussmann series fuses 3 Catalog number tables 4 Specifications 2 Ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Number of poles . . . . . . . . . . . . . . . . . . . . . . . . 2 Agency information. . . . . . . . . . . . . . . . . . . . . . 2 Terminals and conductors . . . . . . . . . . . . . . . . 2 Terminal screw torque . . . . . . . . . . . . . . . . . . . 2 Mounting . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Open fuse indication. . . . . . . . . . . . . . . . . . . . . 2 Ambient storage and operating temperature. 2 Flammability rating. . . . . . . . . . . . . . . . . . . . . . 2 Lockout/tagout provisions. . . . . . . . . . . . . . . . . 2 Circuit labeling provision . . . . . . . . . . . . . . . . . 2 Carton quantity . . . . . . . . . . . . . . . . . . . . . . . . . 2 Class G. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Class CC. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 UL midget. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 IEC 10x38 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Dimensions 5 Panel mounting layout 5 Technical Data 10372 Effective December 2015 Low Profile Compact Circuit Protector (CCPLP) UL Class G, CC, midget and IEC 10x38mm fused disconnect switches Catalog symbol: • CCPLP-(poles)-(amps)-(terminal) Description: The revolutionary Bussmann® series Low Profile Compact Circuit Protector (CCPLP) fused disconnect switch is available in 1-, 2and 3-pole versions for UL® Class CC (1/10-30A), Class G (20A), 13/32”x1-1/2” midget UL (1/10-30A) and IEC 10x38 aM/gG (0.16-32A) fuses. Agency information • Finger-safe IP20 from panel front • CE compliant • RoHS compliant • For Class G fuse versions • UL 98 Listed, File E302370, Guide WHTY • • The CCPLP has the smallest footprint of any UL 98 Listed fused disconnect switch along with up to a 200kA SCCR to help improve equipment SCCR. Class CC and G versions are easily selectively coordinated with the upstream Bussmann series CUBEFuse™ using published fuse ampacity ratio tables. • Unique panel mounting permits easy integration into many panel designs and provides a high SCCR alternative to low profile circuit breakers on the market. Specifications: Frequency • • • • • • cULus to CSA Standard 22.2 No. 4-04, File E302370, Guide WHTY7 • IEC 60947-3 AC-23A For UL midget and 10x38 IEC fuse versions • UL 508 Listed, File E320230, Guide NRNT • cULus Listed to CSA 22.2 No. 14-05, File E320230, Guide NRNT7 • IEC 60947-3 AC-23A • Screw terminal - #10-32 phil-slot screw with external tooth lock washer — use with properly rated/UL Listed ring or fork terminal • Pressure plate terminal - #10-32 phil-slot screw — single 22-6AWG solid or stranded 50/60Hz Impulse voltage • For Class CC fuse versions • UL 98 Listed, File E302370, Guide WHTY Terminals and conductors 75°C/90°C Cu Ratings • IEC® 60947-3 AC-23A 8kV Terminal screw torque Volts 20 Lb-In (2.2 N•m) • 600Vac (Class CC up to 30A, Class G 20A) • • 550Vac (10x38 IEC Class aM 0.16-16A) Mounting • 500Vac (10x38 IEC Class gG 0.5-25A) • Front panel mounting with customer supplied M3 screws • 400Vac (10x38 IEC Class aM 20-32A, gG 32A) • Mounting screw torque 4-5 Lb-In (0.4-0.5 N•m) • 240Vac (13/32” x 1-1/2” midget UL 30A) Open fuse indication* Amps • Up to 30A (UL) • Up to 32A (IEC) • Local open fuse indication provided by a orange neon lamp on each pole, minimum voltage 90Vac * Open fuse indication requires an energized, closed circuit with an open fuse in the CCPLP and the switch in the ON position. SCCR Ambient storage and operating temperature • 200kA (Class CC) • 120kA (10x38 IEC Class gG and aM) • • 100kA (Class G) Flammability rating • 10kA (13/32”x1-1/2” midget UL) • Poles • 1-, 2- and 3-pole factory configured • 2- and 3-pole versions feature ganged switches and phase barriers. -20°C to 90°C, 85% relative humidity non-condensing UL 94 V2 Lockout/tagout provisions • Brady pin-out device, P/N 90844 Circuit labeling provisions • Accepts up to two universal marker labels (P/N TM26CB) Carton quantity • 12 poles (1-pole: 12 units, 2-pole: 6 units, 3-pole: 4 units) Minimumn enclosure size • 2 Eaton.com/bussmannseries 6”x6”x4” per UL 98 Listing Low Profile Compact Circuit Protector (CCPLP) UL Class G, CC, midget and IEC 10x38mm fused disconnect switches Features: • Effective December 2015 Available Bussmann series fuses: Suitable for global installations accepting UL Class G and CC, midget or IEC gG and aM fuses • Full voltage rated up to 600Vac • High Short-Circuit Current Ratings (SCCR) up to 200kA (UL) and 120kA (IEC) • Technical Data 10372 Mounting and panel layout dimensions match common low-profile circuit breakers to provide an easy, alternative fused circuit protection solution. • Disconnect rated to provide means for load isolation • Extremely compact design at 19mm wide per pole • Class CC version is suitable for branch circuit disconnect and branch circuit protection Fuse Class CC Type/description LP-CC time-delay, current-limiting Volts Data sheet No. 600Vac 1023 CC FNQ-R time-delay 600Vac 1014 CC KTK-R fast-acting 600Vac 1015 G SC time-delay (20A) 600Vac 1024 M FNM time-delay 250Vac 2028 1012 M FNQ time-delay 500Vac M KTK fast-acting 600Vac 1011 M BAF fast-acting 250Vac 2011 M KLM fast-acting 600Vac 2020 gG C10G (0.5-25A) 500Vac 720115 IEC 10x38 version is suitable for branch circuit disconnect and branch circuit protection gG C10G (32A) 400Vac 720115 aM C10M (0.16-16A) 550Vac 720115 • Local open fuse indication on each pole standard aM C10M (20-25A) 400Vac 720115 • Finger-safe IP20 from panel front for added safety • Built-in switch handle / fuse access door interlock prohibits removing the fuse under load • Lockout/tagout provisions made by using Brady pin-out device P/N 90844 Circuit labeling provisions for easy identification using TM26CB labels (order separately) • • Switch handle (ganged on 2- and 3-pole versions) Fuse access door Open fuse indicating light Mounting holes for customer supplied M3 screws Circuit marking area Phase barrier Lockout/ tagout provision* 10/32 phil-slot screw or pressure plate terminal * Use Brady pin-out device, P/N 90844 Eaton.com/bussmannseries 3 Technical Data 10372 Effective December 2015 Low Profile Compact Circuit Protector (CCPLP) UL Class G, CC, midget and IEC 10x38mm fused disconnect switches Catalog numbers: Class G fuses Catalog number Pressure plate terminal CCPLP-1-20G-P CCPLP-2-20G-P CCPLP-3-20G-P Screw terminal CCPLP-1-20G-S CCPLP-2-20G-S CCPLP-3-20G-S Poles 1 2 3 Volts AC 600 600 600 Amps 20 20 20 SCCR (kA) 100 100 100 Agency information: UL 98 Listed, File E302370, Guide WHTY, IEC 60947-3 AC-23A, CE, RoHS compliant. Class CC fuses Screw terminal CCPLP-1-30CC-S CCPLP-2-30CC-S CCPLP-3-30CC-S Catalog number Pressure plate terminal CCPLP-1-30CC-P CCPLP-2-30CC-P CCPLP-3-30CC-P Volts AC 600 600 600 Poles 1 2 3 Max amps 30 30 30 SCCR (kA) 200 200 200 Horsepower rating (Vac) 120 240 480 0.5 — — — 2 — — 3 4 600 — — 7.5 Agency information: UL 98 Listed, File E302370, Guide WHTY, cULus to CSA Standard 22.2 No. 4-04, File E302370, Guide WHTY7, IEC 60947-3 AC-23A, CE, RoHS compliant. 13/32”x1-1/2” UL midget fuses Screw terminal CCPLP-1-30M-S CCPLP-2-30M-S CCPLP-3-30M-S Catalog number Pressure plate terminal CCPLP-1-30M-P CCPLP-2-30M-P CCPLP-3-30M-P Poles 1 2 3 Volts AC 240 240 240 Max amps 30 30 30 SCCR (kA) 10 10 10 Agency information: UL 508 Listed, File E320230, Guide NRNT, cULus Listed to CSA 22.2 No. 14-05, File E320230, Guide NRNT7, IEC 60947-3 AC-23A, CE, RoHS compliant. 10x38 IEC Class gG and aM fuses Catalog number Screw terminal Pressure plate terminal Poles CCPLP-1-30M-S CCPLP-1-30M-P 1 CCPLP-2-30M-S CCPLP-2-30M-P 2 CCPLP-3-30M-S CCPLP-3-30M-P 3 Fuse class gG aM gG aM gG aM Volts AC (amp range) 500 (0-25) / 400 (32) 550 (0-16) / 400 (20-32) 500 (0-25) / 400 (32) 550 (0-16) / 400 (20-32) 500 (0-25) / 400 (32) 550 (0-16) / 400 (20-32) SCCR (kA) 120 120 120 120 120 120 Agency information: UL 508 Listed, File E320230, Guide NRNT, cULus Listed to CSA 22.2 No. 14-05, File E320230, Guide NRNT7, IEC 60947-3 AC-23A, CE, RoHS compliant. The CCPLP has the smallest footprint of any UL 98 Listed fused disconnect switch along with up to a 200kA SCCR to help improve equipment SCCR. 4 Eaton.com/bussmannseries Built-in switch handle / fuse access door interlock prohibits removing the fuse under load. Low Profile Compact Circuit Protector (CCPLP) UL Class G, CC, midget and IEC 10x38mm fused disconnect switches Technical Data 10372 Effective December 2015 Dimensions (reference) – in (mm): All catalog numbers 2.24 (57.0) 2.74 (69.6) 2.53 (64.2) 1.5 (38.0) 0.75 (19.0) 3.5 1.26 1.66 (32.0) (42.2) (89.0) 2.13 (54.0) 3.83 (97.3) Panel mounting layout (reference) – in (mm): 1-, 2- and 3-poles, all catalog numbers 1.9 (48.3) 1.14 (29.0) Ø 0.13 (3.2) 0.38 (9.7) 1.14 (29.0) 0.38 (9.7) 0.38 (9.7) R 0.004 (0.1) MAX 1.66 (42.2) 1.26 (32.0) 1-pole 1-Pole 0.76 (19.3) 2-pole 2-Pole 1.52 (38.6) 3-pole 3-Pole 2.28 (57.9) Eaton.com/bussmannseries 5 Technical Data 10372 Effective December 2015 Low Profile Compact Circuit Protector (CCPLP) UL Class G, CC, midget and IEC 10x38mm fused disconnect switches The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2015 Eaton All Rights Reserved Printed in USA Publication No. 10372 – BU-SB15166 December 2015 Eaton, Bussmann and CUBEFuse are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. IEC is a registered trademark of the International Electrotechnical Commission. UL is a registered trademark of the Underwriters Laboratories, Inc. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Follow us on social media to get the latest product and support information.
CCPLP-2-20G-S 价格&库存
很抱歉,暂时无法提供与“CCPLP-2-20G-S”相匹配的价格&库存,您可以联系我们找货
CCPLP-2-20G-S
  • 1+1500.760901+194.14634
  • 6+1218.052466+157.57368
  • 12+1122.9614012+145.27220
  • 54+939.8083154+121.57856
  • 102+870.87793102+112.66136
库存:3
